Username: Kingandsons07 Lincoln,
Nebraska
U.S.A
Post Number: 379 Registered: Feb-07
Wednesday, December 19, 2007 - 04:02 GMT i'm think of gettin 2 18" btl's or 1 9917 if i do the 9917 i wll get 1 more later on so i will have 2 9917 by later on next year? this is going to be for daily driving and some comp i'm going to try to get in to the usaci world final's next year in Omaha N.E thanks guy's
Username: Jakeyplaysbass ASU
Post Number: 2210 Registered: Jul-05
Wednesday, December 19, 2007 - 04:04 GMT im pretty sure someone was selling a 9918 on here...
Username: Nyyfan13 Fi SSD
Post Number: 7649 Registered: Jul-06
Wednesday, December 19, 2007 - 04:06 GMT JNoel was I believe. Not sure if he is anymore. Gonna need some serious power and a serious charging system. How much power do you intend on using?
Nebraska
U.S.A
Post Number: 380 Registered: Feb-07
Wednesday, December 19, 2007 - 04:07 GMT whats going to be louder the BTL's or 9917's?
Username: Nd4spd18 Northwest PA
Post Number: 4631 Registered: Jul-06
Wednesday, December 19, 2007 - 04:08 GMT 2 99 series > 2 BTLs And they don't make the 99 series anymore. They now call it the 95 series with composite cone option (thats what the 99s essentially were). Talk to J Noel see if he still is selling his new 9918.......... he had an insane good price on it.
Username: Bestmankind -apem
Post Number: 16151 Registered: Oct-05
Wednesday, December 19, 2007 - 04:10 GMT i don't know which will be louder but the btl's will sound much better.
Nebraska
U.S.A
Post Number: 381 Registered: Feb-07
Wednesday, December 19, 2007 - 04:14 GMT if two 9917 i would run 2 amp's that would be putting out 3200rms each and the btl's full loaded i would think about the same right? and a 300 amp alt and 3 Kinetik 2400 and 1800 under the hood thanks guys
Username: Denali_on_22s You can call me Scroog...
Post Number: 3391 Registered: Feb-06
Wednesday, December 19, 2007 - 04:16 GMT if you intend on doing comps those DDs can use A LOT more for burps
Nebraska
U.S.A
Post Number: 382 Registered: Feb-07
Wednesday, December 19, 2007 - 04:19 GMT its more for daily than com i just want to do some?
Post Number: 4633 Registered: Jul-06
Wednesday, December 19, 2007 - 04:23 GMT Watch the volume when running that amount of power daily.
Nebraska
U.S.A
Post Number: 383 Registered: Feb-07
Wednesday, December 19, 2007 - 04:25 GMT with sub's lol
Nebraska
U.S.A
Post Number: 384 Registered: Feb-07
Wednesday, December 19, 2007 - 04:26 GMT witch mybad
Username: Kingtutus Lincoln,
Nebraska
U.s.a
Post Number: 15 Registered: Dec-07
Wednesday, December 19, 2007 - 04:40 GMT LOL
Nebraska
U.S.A
Post Number: 387 Registered: Feb-07
Wednesday, December 19, 2007 - 04:44 GMT dude i'm doin this for you!! timmy!!!!!!
Post Number: 2211 Registered: Jul-05
Wednesday, December 19, 2007 - 04:45 GMT in 95% of cases ur daily driving box isnt going to be the same as your comp box...unless ur doing sq of course. but looking at the subbies i doubt that! hah. so why not just run 1 sub and half the power for everday and then make a comp box with 2 of the subs and 2x power.
Nebraska
U.s.a
Post Number: 17 Registered: Dec-07
Wednesday, December 19, 2007 - 04:54 GMT thanks Quentin, for posting this but i think ill just do daily, not to many comp. so witch subs will be better for that?
Nebraska
U.S.A
Post Number: 388 Registered: Feb-07
Wednesday, December 19, 2007 - 04:57 GMT the btl's will sound better but the 9518's will get louder! thats what i heard about them
Post Number: 2212 Registered: Jul-05
Wednesday, December 19, 2007 - 04:57 GMT id probably do DD 9500's if you want a daily setup. the BTLs are nice too tho.
Nebraska
U.s.a
Post Number: 18 Registered: Dec-07
Wednesday, December 19, 2007 - 05:06 GMT Ok, thanks jake papa, so will probably do the dd's
Post Number: 4636 Registered: Jul-06
Wednesday, December 19, 2007 - 07:42 GMT I would still get the DDs, simply because I will not buy Fi subs. Google "Fi tinsel slap" to see why.
Nebraska
U.S.A
Post Number: 394 Registered: Feb-07
Wednesday, December 19, 2007 - 10:04 GMT its not that bad? has everyones FI sub gone bad no?
Username: Th3pwn3r Post Number:...
Post Number: 6287 Registered: Jul-06
Wednesday, December 19, 2007 - 12:52 GMT "i don't know which will be louder but the btl's will sound much better." You like how tinsel slap sounds Chad?
Post Number: 16154 Registered: Oct-05
Wednesday, December 19, 2007 - 14:48 GMT my btl's never had tinsel slap. but my 9512 did. lol
Post Number: 6295 Registered: Jul-06
Wednesday, December 19, 2007 - 15:07 GMT ^That's because the casing on the wire had split because it was old. The casing had cracked and you also gave that sub a ton of power
Post Number: 16155 Registered: Oct-05
Wednesday, December 19, 2007 - 15:09 GMT lol true dat. anyways i had no tinsel slap on my btl's. i had those subs for 8 months. i guess i was the lucky one. hahaha
Username: Surferdude9371 Admitin ur an a$$hole ...
Post Number: 338 Registered: Mar-07
Wednesday, December 19, 2007 - 17:21 GMT never heard the 99 series but love my btl. gets loud but doesnt sound like crap
