Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2041 Registered: Jan-06 | i'd ask what songs really hit, but they pretty much all do. i plan on making a cd of just them and need some to put on it. so instead i'll ask whats everyones favorite songs? |
Platinum Member Username: Bestmankind-apem Post Number: 16020 Registered: Oct-05 | my recent favorite is..... get low by low rida. i love how that song hits. also no one by alicia keyes. not only is that song very nice, it hits. for latin choice, i like all the songs by wisin y yandel. |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4872 Registered: Apr-06 | http://www.datpiff.com/search.php?criteria=chopped+and+screwed a bunch of chopped and screwed mixtapes..check it out |
Gold Member Username: JtownTeam Revolution, Texas Post Number: 1113 Registered: Mar-07 | ^those are free downloads? |
Gold Member Username: camBC Canada Post Number: 1284 Registered: Nov-06 | Yup. ESG - Swangin' & Bangin' |
Silver Member Username: Philly306BUILT NOT BOUGHT, North carolina Post Number: 628 Registered: Apr-07 | thanks alot drivin avast went ape sh!t when i tried to download that. |
Gold Member Username: Van_manBoston South, MA Post Number: 3168 Registered: Mar-06 | I just make my own with Audicity. Personally, I dont like the slowed down songs. Ive spedd a few up, and added bass. It is a fun toy to mess with. btw, "In the club" sounds almost the same backwards. |
Silver Member Username: Gavbo211JL Audio 10w3v2, IL US Post Number: 727 Registered: Jan-05 | "In the club sounds almost the same backwards" i'm not sure why i found that so funny, but i got a good chuckle out of that.. lol. is Audicity a downloadable program? that would definatley be something fun to mess around with. |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2380 Registered: Jun-06 | "get low by low rida. i love how that song hits." Flo Rida perhaps.....lol I like Wisin y Yandel too. Burn it up with the R Kelly is good song. |
Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2049 Registered: Jan-06 | i don't care for CS music too much myself, but i love the low bass |
Gold Member Username: JtownTeam Revolution, Texas Post Number: 1121 Registered: Mar-07 | Gavin, yes it's dnldable but you need to be somewhat computer savvy to use it...at least from my exp, which wasn't a good one...lol...I use wavepad |
Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2050 Registered: Jan-06 | ok... i've figured out how to make it sound exactly how i want, but i have a problem. i'm using sound forge and set the rate of play to .85. when i try to save it, nothing is changed. so what i'm now trying to do is find a decent sound capture program, and i'll be good. sucks my other comp had a nice sound card that came with one... o well |
Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2051 Registered: Jan-06 | Success! check it out t.i. - tell em' i said that fileden.com/files/2007/2/24/813795/Track1.mp3 |
Gold Member Username: Denali_on_22sYou can call me Scroog... Post Number: 3347 Registered: Feb-06 | So what program did you use, and how did you do it, Eric? |
Gold Member Username: Denali_on_22sYou can call me Scroog... Post Number: 3348 Registered: Feb-06 | That sounds tight I wanna do that sh!t to a few songs. |
Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2053 Registered: Jan-06 | alright... it may not be the most legit way ever lol, but it works just fine. i open a song with sony sound forge. in that program i set the song to play at any rate i want, in most cases .85x. i then use blaze media pro to capture the sound while i play it in SF. that simple. on a different note, i just discovered eminem speeds up his lyrics on cd |
Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2054 Registered: Jan-06 | i cant stop f*cking around with songs now lol |
Gold Member Username: Denali_on_22sYou can call me Scroog... Post Number: 3352 Registered: Feb-06 | Damn. So I need to download Sound Forge and Blaze Media? Any other ways you know of (I assume no)? Also, Em not sound as lyrical screwed and chopped? But yeah that Sony program costs money and I'm guessing the other one does too. Any chance you could send them to me or tell me where to download free? |
Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2055 Registered: Jan-06 | i'm sure theres a simpler way to do it, but no i don't know of it. i get everything from torrents. just a search, dl, and following the instructions to crack it are necessary. i use mininova and isohunt the most and i noticed it in forget about dre. when i slowed it to .93, he lost his pitch, and sounded a lot more normal. check it out vvv fileden.com/files/2007/2/24/813795/em.mp3 |
Gold Member Username: Denali_on_22sYou can call me Scroog... Post Number: 3354 Registered: Feb-06 | Damn. To me he just sounds different, haha. I'll try to find those on Azureus. How do you record it on Blaze Media while playing it on Sound Forge? Will it be self-explanatory once I have the files? |
Gold Member Username: Livin_loudDo Work Fi Audio Post Number: 2057 Registered: Jan-06 | pretty much. blaze media has an audio capture program in it and it pretty much just takes a few clicks to setup and record. if you need help with the stuff when you have it just let me know |
Gold Member Username: Van_manBoston South, MA Post Number: 3175 Registered: Mar-06 | dl Audacity. Then just open your mp3 file with it and tweek. Audicity has a lot of tweeking stuff. Bass boost, wah wah, echo, repeat. Ive acually made some 80's screwed, as well as speeding up some songs, but changing the tempo and cords to make it sound normal voice, not retarded kariaoke night at the local bar chopped and screwed songs. |
Silver Member Username: Kpa2727Post Number: 782 Registered: May-07 | a more easy way to do allll this withou audacity's steep azz learning curve and has real decent sound capture plus can save at high bit rates like 320 kb or higher. it's called digital audio editor. the serials very easy to find. |
