Silver Member Username: Charlesbhs
Dallas,
Tx
Post Number: 404 Registered: Jan-07
Posted on should i do them ported or sealed? and how many cuft? i know a few of you brought some so what do you recomend? 75rms each Sub's specs: Power Handing : 100w Available Voice Coils : Single 2 & Single 4 Sealed Box Size : .75-1.00cF Vented Box Size : 1.25-1.65cF Qts: .48 Qes: .64 Qms: 7.50 Fs: 32 Re: 4.1 Vas: 40 L Bl: 6.8 T*m SPL: 84.95 dB Sd: 220 cm^2 Xmax: 6.00 mm Voice Coil : 25 mm Mounting depth is about 3 5/8" |
Silver Member Username: Basebalz13
Moneta,
Va
Usa
Post Number: 131 Registered: Aug-07
Posted on bump i wanna know |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 13330 Registered: Jul-05
Posted on the specs say you can go either sealed or ported...I would go sealed just take the FS and divide it by the Qes.... |
Huntsville,
Alabama
U.S.
Post Number: 13332 Registered: Jul-05
Posted on Any thing >50...sealed 50-75...either 75+....ported |
