Silver Member Username: SatgrlPost Number: 940 Registered: Oct-07 | as some of u must know i was still working on fixing my friends VIEWSAT EXTREME because the FTA TESTER told me to purchase that instead of having to figure out what receiver he had because we could not identify his old one...so anywayz...i tried to load the new bin i dont know what im doing wrong..for some reason it says AUTOROLL PROCESSING forever..keys never roll i try to input manually and it still does not work..i turn autoroll off on it still does not work...is it becuz we are using laptop and the laptop and receiver is connected with rs232 cable?...there must be someething wrong that im forgetting..help out thanks |
Silver Member Username: KirankumarPost Number: 180 Registered: Oct-07 | satgrl, why is it that u r always trying to advise other people but don't seem to solve your own problems,or is it that u r scared of killing your own reciever? |
Silver Member Username: SatgrlPost Number: 943 Registered: Oct-07 | african no its just this is a diffrent problem..the questions that people ask and it only uses common sense most of the time..and yes i have experience for many years with this..but not everyone is perfect HELL i think the most experienced people here have problems with their receivers..but what i know about i help...and if i have a question i rely on u guyz to help out...not everyone is perfect.. |
Silver Member Username: KirankumarPost Number: 181 Registered: Oct-07 | i suggest you get help from Nalin.he is a master at this.good luck by the way i didn't mean to be rude,just curious |
Silver Member Username: Koko_wawaPost Number: 116 Registered: Aug-07 | Turn the box off from the back switch and on again. If still autorolling download the new file again. |
Silver Member Username: SatgrlPost Number: 945 Registered: Oct-07 | yeah i know im not mad..its ok i was just explaning to u... |
Silver Member Username: SatgrlPost Number: 946 Registered: Oct-07 | kaka jii i tried that already like over a hundred times.i give up forget it!..lol |
Silver Member Username: KirankumarPost Number: 182 Registered: Oct-07 | are' don't get upset, sorry baba |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1966 Registered: Sep-06 | satgirl, Lets take this one step at a time shall we? At this point I would say start over with this receiver....is it their with you now? |
Silver Member Username: SatgrlPost Number: 948 Registered: Oct-07 | no its not with me i sent it back today.. |
Silver Member Username: SatgrlPost Number: 949 Registered: Oct-07 | lol im not upset jii |
Silver Member Username: SatgrlPost Number: 950 Registered: Oct-07 | ok heres what i do ....... 1.I DOWNLOADED NEW FILE FOR VIEWSAT EXTREME FROM TOTALFTA 2.UNZIPPED 3.PLUGGED RECEIVER INTO LAPTOP with RS232 cable 4.turned off receiver from back 5.OPENED LOADER2 6.BROWSED UNZIPPED FILE (extracted) 7. CLICKED PC--> STB 8. WAIT FOR A FEW SEC then TURNED ON RECEIVER 9.LOADING STARTS EVERYTHING GOES WELL 10.RECEIVER REBOOTS 11.PLUG INTO TV. 12.AUTOROLL PROCESSING .....not rolling 13.REBOOT FROM BACK 14.STILL AUTOROLL PROCESSING 15.MAUNALLY INPUT KEYS! NOTHING NO LUCK |
Silver Member Username: SatgrlPost Number: 951 Registered: Oct-07 | and i am using DN 61.5 and A DELL LAPTOP AND VIEWSAT EXTREME RECEIVER AND A RS232 CABLE! |
Gold Member Username: RtapFL Post Number: 1471 Registered: Jan-07 | satgrl just a hunch but are u using a rs232 null modem cable or a straight rs 232 cable. |
Silver Member Username: KirankumarPost Number: 184 Registered: Oct-07 | satgrl, i am a novice at this but i have read in a lot of forums that sometimes if you have a problem like yours it is better to use a desktop.just a suggestion |
Silver Member Username: Leafs_wingpPost Number: 164 Registered: Sep-07 | Maybe double check which file you are loading... also unplug any else you have in the USB ports. I have had a similar issues while loading new Bins for the Extremes |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1969 Registered: Sep-06 | Are you still here satgirl so sorry we lost the internet for a while...its back on now...we have had terrible weather here and have 4" of snow coming tonight What type of computer you used had Nothing to do with uploading a file. I use a laptop with vista sometimes, a laptop with win98 sometimes, My wife's laptop with XPpro sometimes, Whatever sesktop I have handy so it does not matter... Unless the computer you are trying to use has a comport issue or something ofcouce... Did you put a new satfile in as wel or cheek to be 100%% sure the receiver has every transponder...? We have had lots of people with that receiver losing transponder during the update process... If you lose transponders the receiver will go to a channel be pointed at the correct sat have the correct keys and still do...autoroll processing....forever |
Silver Member Username: SatgrlPost Number: 953 Registered: Oct-07 | im still here sorry...no im not losing transponders..all channels are correct....how do i know when i lose transponders.... |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1970 Registered: Sep-06 | Well I am sorry but I have to go to babysit my family's store overnight So I will not be here to help you sadly.. Please please go to my guide and do everthing it say's. I was going to have you start all over...go download a new copy of the new bin, go get a new copy of the satfile.... https://www.ecoustics.com/electronics/forum/home-video/414416.html |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1972 Registered: Sep-06 | The way you find out is look at your receivers transponder list compared to the list at lgnsat for each sat you receiver.... if you do everyting in my guide, all files get transfers corectly, it will work I have done it that way for over a year with no trouble takes me about 5 min |
Silver Member Username: DrmunnaPost Number: 117 Registered: Oct-07 | smart garal...abhi gold maltab sone ki ban jayegee are intl down on all rec?? |
Silver Member Username: Saqeeb9000Post Number: 752 Registered: Oct-07 | sat grl are u still there? |
