Whats an inexpensive 250+ watt subwoofer amp
Username: Nd4spd18
Northwest PA
Post Number: 4818
Hey guys. I've been into car audio for a long time and post in those sections a lot, but I don't know as much about home audio.
My home stereo is nothing special but good enough for me. 2 channel stereo Technics receiver/amplifier and a set of big 3way Technics speakers.
I just got a subwoofer for free, and I'm looking for a 250+ watts at 4 ohm amplifier to power it. I'd like to keep it as cheap as possible, I don't need real high end equipment. Any amp suggestions?
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2480
I will try to help here. Dont know if you are looking for a plate amp or not but you could check these out.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-805
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-750
A pic is worth 1000 posts!!
Post Number: 11926
Connect the sub out line from your receiver and run it to something like this amp. $100 isn't bad. You know about boxes and such so try and tune lower than you would in your car. I'm happy with my 1000w dayton plate amp.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-804
Post Number: 11927
There you go lol.
It doesn't have to be a plate amp but it's what I prefer.
Post Number: 2481
lol....what is the difference between the amp in my first link and the one in your link? They have different part numbers but it looks like they are the same and they have the same price...
Username: Nd4spd18
Northwest PA
Post Number: 4826
Thanks guys :-) ...... any other input is welcome
Post Number: 11929
Jesse, one has bass boost the other doesn't.
Username: Nd4spd18
Northwest PA
Post Number: 4865
Thanks guys. I ordered the one Paul recommended.
