Vented box
Username: Juancarlos707
El Centro, CA Imperial
Post Number: 22
This might sound like a dumb question but I want to build my own vented box. Is the vent and the length of the vent count as the enclosure as well. the specs say vented box 1-1.8Ft3. Does that include the vent as well??? or I dont count that...
Username: Jesse59672
OKLAHOMA
Post Number: 802
that is not including the port and the actual volume the subwoofer takes up
Post Number: 23
so just count the box volume without the port/vent. like if it was a sealed.
Username: •cam•
BC Canada
Post Number: 1290
Yep.
Post Number: 25
Oh I get It. and the specs also say Fo 30-36Hz. Thats what I dont get. Do you determine that by the length width height of vent or its more than that???
Username: Nickyp0219
Post Number: 213
http://reaudio.com/speaker_box/LPort_Box_Calc.html
Username: Phil_salisbury
Post Number: 473
Well, that all depends on what the manufacturer states for the spec's of the enclosure and they will usually say that the volume is net or gross volume of the enclosure.
Some companies just throw it all together and don't tell ya sh!t beyond that leaving the person to figure out what is the net volume and displacements involved for the spec's.
Never assume anything unless it's stated or noted per what your trying to determine for an enclosure when it comes to designing it.
Post Number: 26
nickyp0219..thank you so much.Thats the website i really needed.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 780
that RE calc is all wrong...
or has it been fixed???
Post Number: 215
Had Greg from Us amps run through the calculations I needed so I imagine its good
Post Number: 27
they didnt tell me if its net or gross.
All I got was a piece of paper that said this.
PORTED:
VB(ft3)=2.00 <is that net or gross,what is net or gross?
Fb(Hz)=32
Slot Port With=3(in)
Slot Port Hieght=14(in)
Port Lenght=48(in)
Post Number: 28
that was the recommended enclosure.
But then I went to the website and it said this diffrently:
1-1.8Ft3
Fo 30-36Hz
Post Number: 474
Well, there ya have it.
Net Volume can be anywhere from 1 to 1.8 cu.ft.
plus your displacements ( sub, port, port walls, bracing )
