Silver Member Username: JemoneStone Mountain, Georgia United States Post Number: 258 Registered: Jan-06 | High output alt is on the way. I am going to run two batteries, how do I install the battery isolator. I know this is a novice question. |
Gold Member Username: CarguyPost Number: 6780 Registered: Nov-04 | The instruction should come with the isolator. If you look at it, you should see battery 1 and 2, alternator and maybe ignition. It's exactly the way it says on the label. Battery 1 = starter, 2 = 2nd battery, alternator = pos from alternator, and ignition= wire from ignition. If you don't know where that is, look in your owner's manual. Also go to this site and read on isolator. It'll show you a diagram on installation. www.bcae1.com GOod luck. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4557 Registered: Jul-06 | What vehicle With GMs you have to use a special type of isolator or you will blow the alternator. |
