B.A.S.S. Acoustic Audio Subwoofers
Username: Xx_elixir_xx
Post Number: 37
I have 3 of the 15" B.A.S.S. series Acoustic Audio subwoofers and there are some problems with them.
Problems:
A. No enclosure specifications.
B. Speaker does not accomplish its full potential because of preasure.
Solutions:
A. DO NOT USE A SEALED ENCLOSURE! Use a ported enclosure that is about 1 cubic foot. The port should have a 2-3in diameter and be 4-5in long.
B. There is so much resistance inside of the subwoofer itself that when you crank the volume it just destroys the voice coil. What you have to do is create 2 holes for better air flow.(Refer to picture for hole location.)
Post Number: 38
Problems:
C. Incorrect power rating.(rated 450w RMS and 900w peak)
Solutions:
C. Correct rating - 100w RMS and 200w peak before holes. 200w RMS and 400w peak after holes are made.
Username: Th3pwn3r
Post Number:...
Post Number: 6216
Lol.
Post Number: 39
Took me a while to get them sounding like they should.
Username: Th3pwn3r
Post Number:...
Post Number: 6217
"B. There is so much resistance inside of the subwoofer itself that when you crank the volume it just destroys the voice coil. What you have to do is create 2 holes for better air flow.(Refer to picture for hole location.) "
Are you sure you didn't mean the spider?
What you should have done was get yourself some good woofers from the start. Nice work figuring things out though.
Username: Denali_on_22s
You can call me Scroog...
Post Number: 3309
Haha. I feel bad for this guy.
Post Number: 40
hey for $40 I did not care. I have 2 12W3v2 D4's and 2 MA80XE. I know Acoustic audio is not good. and no I do not mean the spider.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 78
x2 with Reece Brassler if you only paid $40 then you got what you paid for. lol what do u expect?
Username: Jnoel
AIM= j69noel, KY
Post Number: 702
problem 3: you payed money for those subs
-apem
Post Number: 16029
"C. Correct rating - 100w RMS and 200w peak before holes. 200w RMS and 400w peak after holes are made."
HAHAHAHAHAHAHAHAHAHAHAHA.
Post Number: 41
this is just for other saps(like me) that have also purchased these subwoofers.
Post Number: 3313
i didn't think anyone actually bought those things. do you want some advice?
Post Number: 42
hahaha I know other people have and I know people want info on them.
THEY SUCK
Username: Nd4spd18
Northwest PA
Post Number: 4528
LMFAO this thread f*ckin made my day
Those are the POS subs they sell on ebay for cheap as hell.
Post Number: 3332
honestly, its more worth than the speaker is worth... i mean seriously man... blow those f uckers up and call it a day... wake up tommorrow and buy something worthwhile
Post Number: 43
I have good stuff.
