Box Help.
Username: Comerz
Post Number: 85
I am now looking to build a box for the sub and amp I have ordered. There is a problem though, i know nothing about building boxes :-(.
I was wondering if anybody could list the major steps you have to take in order to have a great box. Ex, what type of wood, what thickness, how to get a good seal, where to find out how big to make the box, and basically somewhere where i can find out the specs so i can build it to that.
I am making a box for a 2 ohm 12" alpine type R for my corolla 94.
Thanks for any help, i really need it.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 73
phil @ www.woodlawncabinetry.com hit him up on that page, he knows everything and he'll work with you. i had a box made by him i picked up on dec 1st, trust me from personal experience he's great at what he does.
Username: Comerz
Post Number: 86
yea, i just dont go tthe money to order up a box, plus it will take some time with the delivery, especially around this time, im kind of more leaning towards making my own box.
It cant to too difficult.
I sthere like a site or anything on where to look up specs for certain subs. Also how to build a good sub box?
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 74
well you got a type r 12" right? well theres the specs for your sub i think...
http://www.alpine-usa.com/US-en/products/product.php?model=SWR-1222D&lang=en&tab =F
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 75
or ask JK32SHO he helped me out, i think he makes boxes too....
Username: Comerz
Post Number: 87
Thanks V.T.
Lol thats gunna be harder than expected, i wouldnt be able to translate the specs for making a box.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 76
yep, to build a box you gotta have a knowledge of what your doing or else its going to sound like sh*t and fall apart on you...lol but i think u shuld hit up JK32SHO he'll def help u out, thats his name on ecoustics plus his aim.
Username: Comerz
Post Number: 88
well, if you know your specs on how big to make the box, how much harder can it be? If you are pretty good at carpentry i cant see the problem here. Its a box.
Username: Phil_salisbury
Post Number: 472
Chad,
If you have the skills of basic woodworking/carpentry, building the enclosure should be a breeze for you provided you have the tools to cut the parts to size and put it together.
Use the spec's of the subwoofer recommended enclosure and use Resonant Engineer box designer to get the box to the size you want based on what your building it to fit. The designer provides all the parts as to the sizes you need.
Now if your for someone to do the leg work for the enclosure spec's/part sizes, speak up as to what the enclosure needs to fit for the space ya have and we'll get it done for ya.
The rest is up to you.
Username: Jesse59672
OKLAHOMA
Post Number: 800
you looking for ported or sealed?
OKLAHOMA
Post Number: 801
or bigger pics:
http://aycu30.webshots.com/image/35869/2003830194772910954_rs.jpg
http://aycu25.webshots.com/image/35064/2003813522606247666_rs.jpg
http://aycu23.webshots.com/image/38222/2003806364249195262_rs.jpg
http://aycu40.webshots.com/image/35039/2003861978582120919_rs.jpg
http://subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=15&Dia=6&Xmax=18.1&Vd=.071&NumW=1&Vb=2.2&Fb=35&Qts=&Vas=&Fs=&CE=0
OKLAHOMA
Post Number: 805
30 x 15 x 15
2.2 net cubic feet, tuned @ 35hz
Username: Comerz
Post Number: 89
o nice thx jessie, yea im lookin for ported. IS that how big id make it for an alpine?
OKLAHOMA
Post Number: 809
it's just your preference, unless your building exactly to alpines recommendations. i think 2.2 cubes @ 35 hz would sound good, but in the end it's just up to you and what kind of music you listen to.
