Jl vs. boston
Username: Davidt487
im looking for a sub to go under the seat in an extended cab truck. ive narrowed it down to
boston g1
jl w1v2
any other sugg. would be great
thx
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7251
ill get the w1v2
if boston is you want the g5 is the sub to go for.
Username: Santa_fe
02 Hyundia Santa Fe, 120.3 db not...
Post Number: 415
umm there are some shallow mount kickers out there, im not sure how you feel about them...but out of thoes two JL for sure
Username: Davidt487
ive heard the jl audio, but never the boston and i can get a desent price on the g1 but i dont no what to expect. im looking for sql.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 693
id get some shallow mount subs, a w1 really wouldnt be that loud imo
Username: Davidt487
ive never heard the shallow mount subs. has anyone ever had any dealing with them? if so what brand? im not a kicker fan and the only other ones i know of are audiobahn power acoustics kole audio and pioneer.
again thanks for any input
Username: Davidt487
Username: Davidt487
Username: Cblaze
Post Number: 705
alpine,sony,rockford fosgate, &kenwood also makes them
Username: Ctmike
Ct.
Post Number: 5530
here's another:
http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=106
Username: Davidt487
sorry bout the triple post comp is acting up. do you all think any of these will be as loud as a w1?
Username: Ctmike
Ct.
Post Number: 5531
only heard the kicker and pioneer shallows, can't help you there.
said you have an extended cab, why not just run a regular sub in there?
Username: Cblaze
Post Number: 706
thats what i would do just use 1 seat or somethang and put one sub in there
Username: Davidt487
Post Number: 7
well i was looking at the jl w1 but santa_fe said i might try them and i was trying to get some in put because ive never heard them. im looking for a good loud sub for a 4 door truck (under the seat)
Username: Davidt487
Post Number: 8
need all the seats ive found boxes that fit but they dont have very deep mounting depth so im trying to find the best sub for my project.
thanks again for the help
