Two amps
Username: Nismo69
how do u fuse the power wires if u run two amps from a distro bloack?.also if i run 4 guage to the block and then two 8 guage to the amps...will it cause problems if i turn one amp off and have the other running?
Username: •cam•
BC Canada
Post Number: 1275
Welcome to Ecoustics.
You add up the max current draw of the 2 amps.
Nope, there will be no problems.
Username: Nismo69
do i fuse the 4 guage only?
Username: Nd4spd18
Northwest PA
Post Number: 4473
Depends on how long the 8 gauge wires are going to be. Longer than ~2ft, they should be fused.
Username: •cam•
BC Canada
Post Number: 1277
Never used a distribution block, but don't some of them have fused outputs?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 906
Mine does. 1 input, 2 outputs through a fuse.
