8 inchers
Dave
does anyone know of some good 8 inch subs that come in either a dual 4, or single 2 ohm configuration, and that can handle a real 1700 watts as a pair. Thanks and prefferably with a higher friequency response rating.(These are going to be my mid-bass drivers). Thnx.
kbizzle
why 8" they dont make much of sound they are just like a regular speaker damn near if i were u id try at least for a two 10"
low and loud
actually 4 decent 8 inch subs would produce more bass than 2 10 inch subs. also it depends on the music u listen 2, rave/tecno would suit the 8s better where as r&b would suit 10s or 12s better because of how low they can drop.
get 2 kicker solobaric 8" L7, if you get the boxes ported right you will get these 8's louder than most of the 2 10's u can buy
Jl 8w7 that's what you want. Prolly louder than 2 12's definetely 2 10's by most brands.
u guys r leavin out audiobahn flame q's when your talkin bout 10's right. yeah thats what i thought. hha. Flame q's r the best
