Does anyone know of any cheaper alternatives to the Kicker ZX650.4? I would like to find a similarly good amp but for less. The ZX650.4 is a bit over what i wanted to spend for my amp. Thanks for your suggestions and opinions!
the amps you listed are totally differnt on rms. the kicker is more powerful and is underrated. im sure the jbl will put out rated power but not much more. the kicker is just an all around BETTER amp. look on ebay for a refurbished kicker if you are pressed for cash!
all i need is 100w x 4 (4ohm), so the kicker is a little overkill. basically im looking for the next best thing to kicker, BUT a bit less expensive. I would rather not buy a refurb...
