Where to get polyfill
Username: Nickyp0219
Post Number: 208
where are some places to get cheap polyfill? Is it safe to use in ported enclosures?
Username: Jtown
Team Revolution, Texas
Post Number: 1117
hobby lobby
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1790
Well it's safe if you staple it in or something, but otherwise it will blow out the port. You can get it at Walmart as well.
Username: Phil_salisbury
Post Number: 469
Any fabric or arts/crafts store will have it.
Post Number: 209
how do you calculate internal box volume w/ driver displacement? thanks
Username: Insearchofbass
Post Number: 7317
get the kind that comes in sheet form and staple or glue it in depending if its temporary or permanent....temp to test permanent once you find the right amount
Post Number: 7319
for ported boxes use the sheet form anyway
