Dual xdvd8181 -- want to bypass brake signal...please help
Username: Cj123
i recently bought a '95 acura integra, that came with a dual xdvd8181 already installed. i want to ground the yellow wire so that it does not detect the brakes, but have no clue how to get the unit out so i can look in the back (i am assuming that is where the wires are). if you know how to remove the unit so i can ground the wire, please help. thanks.
Username: Wickedindian
OK PEOPLE, I HAVE THE DUAL XDVD8181 just installed, you don't need to do any kind of code to get the video to bypass. this is what you have to do
Get a toggle switch, one that flips one way for ON, and the other way for OFF. connect parking brake wire (yellow/blue) to one end of the switch and the other end to the ground of the radio (Black wire) leave the switch in off position, turn on radio and insert dvd, when you get the blue screen, flip switch ON OFF ON wait 5 seconds and video will come on. That it fellas.
any problems contact nitrohouse@gmail.com
