Bronze Member Username: Nels2kPost Number: 58 Registered: Mar-06 | what set up is needed for 118.75. is it the same as 121. |
Silver Member Username: RunnerguyPluto Post Number: 892 Registered: Sep-06 | Found this C & P from ekb.dbstalk.com Many international channels added to 118.75 (Listed as 119k on this chart). They all appear to be available to subscribers (JohnH at DBSTalk.com)) 657 ONGME ADDED TO Tp 17 on AMC-16 at 118.75w 658 BTN ADDED TO Tp 17 on AMC-16 at 118.75w 661 WOWTV ADDED TO Tp 17 on AMC-16 at 118.75w 668 JSTV ADDED TO Tp 17 on AMC-16 at 118.75w 676 JIC ADDED TO Tp 6 on AMC-16 at 118.75w 677 DRAGN ADDED TO Tp 18 on AMC-16 at 118.75w 679 PHNIN ADDED TO Tp 23 on AMC-16 at 118.75w 680 PHNIX ADDED TO Tp 14 on AMC-16 at 118.75w 681 CCTV4 ADDED TO Tp 14 on AMC-16 at 118.75w 685 ETCHI ADDED TO Tp 14 on AMC-16 at 118.75w 686 BEJTV ADDED TO Tp 6 on AMC-16 at 118.75w 688 JET ADDED TO Tp 14 on AMC-16 at 118.75w 689 TTV ADDED TO Tp 23 on AMC-16 at 118.75w 690 CTV ADDED TO Tp 23 on AMC-16 at 118.75w 691 CTS ADDED TO Tp 23 on AMC-16 at 118.75w 692 VLAND ADDED TO Tp 23 on AMC-16 at 118.75w 693 PTS ADDED TO Tp 23 on AMC-16 at 118.75w 694 CCTV9 ADDED TO Tp 18 on AMC-16 at 118.75w 695 CCEF ADDED TO Tp 18 on AMC-16 at 118.75w 696 CCMOV ADDED TO Tp 6 on AMC-16 at 118.75w 697 CCENT ADDED TO Tp 6 on AMC-16 at 118.75w 699 CCOPR ADDED TO Tp 6 on AMC-16 at 118.75w 700 GUAND ADDED TO Tp 18 on AMC-16 at 118.75w 701 FUJTV ADDED TO Tp 6 on AMC-16 at 118.75w 704 KBS ADDED TO Tp 17 on AMC-16 at 118.75w 705 ARANG ADDED TO Tp 17 on AMC-16 at 118.75w 706 CYRTV ADDED TO Tp 6 on AMC-16 at 118.75w 707 PACVI ADDED TO Tp 18 on AMC-16 at 118.75w 708 HUNAN ADDED TO Tp 6 on AMC-16 at 118.75w 712 MABHY ADDED TO Tp 2 on AMC-16 at 118.75w 725 DWTV ADDED TO Tp 14 on AMC-16 at 118.75w 726 PRSBN ADDED TO Tp 14 on AMC-16 at 118.75w 731 TV5 ADDED TO Tp 3 on AMC-16 at 118.75w 732 RFI ADDED TO Tp 3 on AMC-16 at 118.75w 735 TRACE ADDED TO Tp 3 on AMC-16 at 118.75w 749 ABNAM ADDED TO Tp 2 on AMC-16 at 118.75w 751 TELSD ADDED TO Tp 2 on AMC-16 at 118.75w 753 TAP1 ADDED TO Tp 2 on AMC-16 at 118.75w 754 TAP2 ADDED TO Tp 2 on AMC-16 at 118.75w 755 CHONE ADDED TO Tp 2 on AMC-16 at 118.75w 785 CARIB ADDED TO Tp 3 on AMC-16 at 118.75w 799 GEMNI ADDED TO Tp 7 on AMC-16 at 118.75w 800 SURYA ADDED TO Tp 7 on AMC-16 at 118.75w 801 KAIRA ADDED TO Tp 3 on AMC-16 at 118.75w 802 TEJA ADDED TO Tp 3 on AMC-16 at 118.75w 803 UDAYA ADDED TO Tp 17 on AMC-16 at 118.75w 804 NTV ADDED TO Tp 3 on AMC-16 at 118.75w 805 TARA ADDED TO Tp 17 on AMC-16 at 118.75w 806 CHNLI ADDED TO Tp 3 on AMC-16 at 118.75w 810 ASIFM ADDED TO Tp 3 on AMC-16 at 118.75w 811 SAWLD ADDED TO Tp 14 on AMC-16 at 118.75w 812 AMDES ADDED TO Tp 7 on AMC-16 at 118.75w 818 ATN ADDED TO Tp 14 on AMC-16 at 118.75w 905 ARMTV ADDED TO Tp 2 on AMC-16 at 118.75w c/p replace the linear lnb with a circular lnb. locate and peak echostar 7 at 119, lock down disk. replace with linear lnd . set antenna as with 121 with lo frequency st to 10750. signal and quality will be zero since there is no transponder listing yet. do blind scan to locate active transponders. channel will populate with international as well as the play*boy channel. |
Bronze Member Username: Nels2kPost Number: 59 Registered: Mar-06 | so does that mean that you need a 33" dish for 118 |
Gold Member Username: NydasPost Number: 5920 Registered: Jun-06 | nel rib asked: "what set up is needed for 118.75. is it the same as 121." It is not the same as 121 A lot of internationals have moved from 121 to 118.7. It is KU Band but requires 30-33" Dish. You will need a Universal LNB SPECIFIC to 119/118.7 combination. You can get one at http://www.partsforhdtv.com/lnb-circular-dss-10750-11250-c-81.html?gclid=CJbi8pG qqJACFQdEFQod8iT67A Also lots of them at ebay. Also from DN as a kit. |
Silver Member Username: RunnerguyPluto Post Number: 894 Registered: Sep-06 | 30" dish and Xtreme LNBF works. I know that much |
Bronze Member Username: Nels2kPost Number: 61 Registered: Mar-06 | thanks Nalin, so your saying that you use the same 33" dish but i can't use the same as i did for the 121. i have a separate dish for 119. |
Gold Member Username: NydasPost Number: 5924 Registered: Jun-06 | You can try and swing the 121 dish to line up with 118.7 and see if the current LNB works. You have to do it anyway. You will probably need to change the LNB, or you may get by with a signal amplifier. |
New member Username: ManePost Number: 9 Registered: Sep-06 | you need at least 33" dish and circular LNB to get 118.7 |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1965 Registered: Sep-06 | Mane, 118 requires a liner LNB not Circular as stated above please do not confuse this. Nel Rib, Go get a motorand QPH-031 for your 31" dish 100's of internatal channel;s on true FTA that are in the clear ( WORKING meaning you can watch them) All the time no BIN files Needed! I can get it with my qph-031 and 31" motorized dishso it can be done Go to lgnsat and get the transponders for it and scan it...it is LOW power so most will be very low signal and quality but will come in.. |
Silver Member Username: Koko_wawaPost Number: 117 Registered: Aug-07 | Universal circular LNB is required for Anik3 (118.75) and 30'' dish is fine |
New member Username: ManePost Number: 10 Registered: Sep-06 | liner lnb you use for gettingHere are the steps to convert your standard linear LNB to a circular LNB to be used for satellites broadcasting in the FSS using circular polarization such as Anik F3 at 118W. Materials needed: a) Sharp knife b) Plastic strip (an expired credit card, or your ROM3 CAM's are good for this purpose) c) Ruler d) Teflon tape e) Screwdriver or butter knife (I used the butter knife) Note: If you remove the dustcap of a circular lnb and a standard linear lnb, you would notice an obvious difference. It is the absence and presence of a plastic strip inside the feedhorn of the linear and circular lnb's, respectively. Procedure: Remove the lnb's dustcap by first twisting and pulling it out of the feedhorn until there is enough gap for you to insert your screwdriver/butter knife (if you can not twist it, just go ahead with the next step). Pry the dustcap off the feedhorn. Don't worry, there is nothing that gets damaged inside. (Sorry, I did not take pictures of my project). If you examine the inside of the feedhorn closer, you will see notches where you will insert the plastic strip. Using your sharp knife, cut a strip from your plastic card measuring 19mm wide (to allow for error) by 32mm long (my strip is 40mm long). Actually, the plastic strip inside the circular lnb measures 18mm x 32mm. Try to insert your strip along the notches inside the feedhorn oriented like a forward slash, if it won't go in, just scrape the sides of your strip until you can insert it...make sure it is reasonably snug. Wrap a few turns of Teflon tape around the rim area of the feedhorn if you damaged a part of it when you removed the dust cap to seal the inside of the feedhorn. Replace the dustcap. That's it! You're done! You now have an FSS lnb with circular polarization. Receiver settings: LNB type: Standard or Single LNB freq: 10750 22KHz option = ON 121 signal here you can even convert your liner lnb to circular lnb then use for 118.7 here are steps I c&p from another side I tried it it works perfect |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1968 Registered: Sep-06 | HOw many people are going to post in this thread a cicular LNB is needed it will not work! The sat is liner. If you point a cicular LNB at 118 you will get guess what..................119 That LNB DN uses for 118 is guess again....liner |
Silver Member Username: KirankumarPost Number: 183 Registered: Oct-07 | what is 118 ? i have 61.5 am i effected,do i need to make some changes? |
Gold Member Username: RtapFL Post Number: 1469 Registered: Jan-07 | Here is a list of satellites and the correct lnb's to use with them: 61.5W Echo 3 - use standard circular lnb - 11250 MHz 63W Estrela - use linear lnb, either universal or standard linear- 10750 MHz 71.8W Nahuel 1- linear lnb, either universal or standard linear- 10750 MHz 77W Echo 4 - circular standard lnb - 11250 MHz 79W Amc 5 - linear lnb, either universal or standard - 10750 MHz 82W Nimiq 2 - circular standard lnb= 11250 MHz 87W Amc 3 - --- linear lnb, either universal or standard - 10750 MHz 91W Galaxy 11- linear lnb, either universal or standard- 10750 MHz 91W Nimiq1&3- circular lnb standard= 11250 MHz 93W Intelsat 6- linear lnb, either universal or standard-10750 MHz 95W Galaxy 3c- linear lnb, either universal or standard - 10750 MHz 97W Intelsat5- linear lnb, either universal or standard - 10750 MHz 101W Amc 4 - linear lnb, either universal or standard- 10750 MHz 103W Amc 1- linear lnb, either universal or standard- 10750 MHz 105W Amc 15- linear lnb, either universal or standard- 10750 MHz 107.3W Anik - linear lnb, either universal or standard- 10750 MHz 110W Echo 8 & 10,X - circular lnb standard - 11250 MHz 111W Anik f2 - linear lnb, either universal or standard - 10750 MHz 116.8W Satmex5 - linear lnb, either universal or standard - 10750 MHz 119W Echo 7 - circular lnb standard - 11250 MHz 121W Echo 9 - linear lnb, either universal or standard - 10750 MHz 123W Galaxy 10r - linear lnb, either universal or standard - 10750 MHz 127W Galaxy 13 - linear lnb, either universal or standard - 10750 MHz 129W Echo 5 - circular lnb standard - 11250 MHz 148W Echo1 & 2 - circular lnb standard - 11250 MHz |
Gold Member Username: NydasPost Number: 5926 Registered: Jun-06 | RTAP: Same typical carelessness. This is about 118.75. The long list you just published does not have it, because it was not there when the list was published. Therefore your C/P is just a waste. You earlier published another obsolete list from a June 2006 posting at Ecoustics. |
Gold Member Username: NydasPost Number: 5927 Registered: Jun-06 | The 118.7 anic F3 requires a special LNBF. with a 39" dish you may get away with your existing LNBF (circular or linear), but will get 3 db loss. You can compensate it with an amplifier. However, it is best to have the correct LNB. http://www.partsforhdtv.com/ have the right info and LNBs. At $20 it is a good buy. |
Gold Member Username: NydasPost Number: 5928 Registered: Jun-06 | African: This RTAP keeps on intefereing wiht his old C/Ps. Many of the internationals from 121 have been moved to 118.7 Anik F3. It is a KU band sat but requires a 30-33" dish. You also need a special Universal LNB, and if you instal this, you will get both 119/118.7. This is the direction set for you by DN There is talk of 61.5W and 148W being reduced to make room for HD, but I have no confirmation of it. |
Silver Member Username: KirankumarPost Number: 186 Registered: Oct-07 | thanks Nalin |
