Mono Amp Help
Username: Comerz
Post Number: 76
What is a good amp for 1 15" alpine type R?
i was thinking the 1200D hif amp. Dont got enough money for the kicker 1000 amp.
also, would i want a mono block for just 1 15" sub?
Lemme know what u guys think, peace
Username: Texas_bass
Houston, TX
Post Number: 538
the hifonics amp wont be putting out all 1200 there about 80% eff
Username: 420alldaylong
Post Number: 3006
Budget for amp?
What coils?
Username: Comerz
Post Number: 78
my budget for amp is pretty strict, around $300 max. Thats why i was aiming for the 1200D Hif.
I also aimed towards that because the 606D wouldnt be enough power, that one would be more than enough for one 15".
You ask what coils, i was gunna ask that same question, i dont know what to look for.
I think since its only 1 sub it will be 2 Ohma also?
Username: Ctmike
Ct.
Post Number: 5514
type rs' come in either dual 2ohm or dual 4ohm vc. either pick the amp you want first and match the sub with it, or vice versa. so if you get a dual 4ohm vc, get an amp that'll do about 600-800wrms at 2ohm. little more if you're smart with it.
Username: Ctmike
Ct.
Post Number: 5515
just grab a dual 2ohm vc type r and a sundown sae1000d. amp can be bought from dealer for $300 shipped, and is alot better than that hifonics amp you were thinking of.
Username: Jemone
Stone Mountain, Georgia United States
Post Number: 248
What is this sundown company i keep hearing you guys talk about? You know im in the south, basically alll we have is flea market crap down here . Some one give me a link.
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 916
how about an audioque 1200D
