Cheap hi output alternators!!
Username: Jemone
Stone Mountain, Georgia United States
Post Number: 216
For those not wanting to break the bank but still needing something better than factory.
http://www.db-starter-alternator.com
200 amps=$200
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J... USA
Post Number: 647
Too bad they don't make alternators for 05 camry's damn japs makin complicated alernators lol jk. : (
Username: Vtouch06
Q-TowN, PA
Post Number: 12
x2^^
Username: Nd4spd18
Northwest PA
Post Number: 4451
Thanks for the link but I've only recommended them about 1000 times so far...... I have an alt from them.
FYI those are good quality HO alts, and yes they have good prices.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 665
ahhhh
Username: Clouduz
Post Number: 250
they need a better selection don't have one for my suv
Username: Th3pwn3r
Post Number:...
Post Number: 6186
Those HO alts only put out 105 amps at idle. That's not very good...
Username: Nd4spd18
Northwest PA
Post Number: 4488
Better than stock, same as EA, same as Iraggi Dominator series (for GM cars anyways).
Username: Th3pwn3r
Post Number:...
Post Number: 6190
Yea... we need alts with higher idle amperage :-(
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1448
They dont have one for an Ava
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 5661
Rob, you do realize that HO/Dom/Ohio alts are rated at 1200-1500rpm...right?
Username: Th3pwn3r
Post Number:...
Post Number: 6194
"Rob, you do realize that HO/Dom/Ohio alts are rated at 1200-1500rpm...right?"
Of course but is that the revs of the engine or the revs of the under drive pulley?
http://cgi.ebay.com/ebaymotors/300amp-Amputator-Series-Iraggi-Alternator-Chevy-G MC_W0QQcmdZViewItemQQcategoryZ33573QQihZ018QQitemZ7963120329QQrdZ1QQsspagenameZW D1V
That's the alt I have and 135 at idle is just not enough so I raised the idle up a bit on my engine which doesn't make stopping that great and makes my gas mileage a bit worse as well. I wasn't saying that we need alts with higher amperage to bash the companies listed here in this thread but I said that about needing more amperage at idle from ALL alternators. It would be pretty nice to have 300 amps at idle wouldn't it? :-)
Username: Boomtank
Rochester, NY USA
Post Number: 406
rob get another one of those alts and your almost there 270amp idle.
Username: Th3pwn3r
Post Number:...
Post Number: 6198
I thought about taking out my A/C and installing another alt in it's place.
Username: Boomtank
Rochester, NY USA
Post Number: 409
Im in the process of doing the same thing. Putting 2 185amp alts in for now then upgrading later when i really need that much current.
Username: Carguy
Post Number: 6750
Rob, don't do it. Thanks to global warming, you'll need it.
If the car's a convertible, then that's another story.
Username: Th3pwn3r
Post Number:...
Post Number: 6199
^Thanks for looking out Isaac but even though it's been charged with R-something last summer it still takes forever to get to a decent temperature because of the large cabin and it just doesn't seem to work all that great. Even when it was really hot I never even bothered to attempt to use it, I work in a warehouse and it gets extremely hot at times inside trucks and what so I'm used to the heat.
Username: Nd4spd18
Northwest PA
Post Number: 4518
300 amps at idle just isn't realistic given the physical size of the alternators.
