Bronze Member Username: Xxxx1234Post Number: 23 Registered: Sep-06 | Looks like the DVB card coder doing a better job this time. It may be a good idea to get a backup solution when these crazy ECMs flying around. |
Bronze Member Username: Silverlion80Post Number: 45 Registered: Nov-07 | i have vs xtreme for emunation |
Bronze Member Username: Silverlion80Post Number: 46 Registered: Nov-07 | i mean can i use it for emunation |
Bronze Member Username: Jagr1234Post Number: 57 Registered: Nov-07 | no do a search on emunation and see what its for |
Bronze Member Username: YakovakiPost Number: 35 Registered: Sep-07 | please give me more details about this dvb card stuff??? do i buy a dvb card then use different apps for it? or does it have its specific support?? |
Bronze Member Username: Xxxx1234Post Number: 25 Registered: Sep-06 | JB: You can get all the information in this thread: Thread: Emunation first again. Everything is work ing accordingly. https://www.ecoustics.com/electronics/forum/home-video/412215.html |
Bronze Member Username: YakovakiPost Number: 37 Registered: Sep-07 | thanks very much...this is very helpful (and yes i know i should have searched better :P) i did a google search and did not help very much i will take a look xxxx1234 |
Bronze Member Username: Xxxx1234Post Number: 27 Registered: Sep-06 | JB: You are welcome. I always like to help polite, intelligence people like you. |
Silver Member Username: Saqeeb9000Post Number: 617 Registered: Oct-07 | i can't see any help here bro.. ... there is nothing here ...... |
Bronze Member Username: YakovakiPost Number: 39 Registered: Sep-07 | its all there sada... basically you need to get a dvb card like a twinhan then you need to load some software on your computer and do some reading...im gonna give it a shot this week ok so like xxxx1234 said: hardware is a twinhan card the connect rg6 in the rest is settings and software get: something like - MyTheatre and then add the plug-in Emunation (and get the updated version like an fta fix) good luck and thanks again xxxx1234 |
Silver Member Username: Oleg1474Florida Usa Post Number: 503 Registered: Aug-06 | Att. (EURO/ECM666) coming soon !!!!! |
