Autotek MM1400.1D
Username: Snowball123
West Allis, WI United States
Post Number: 62
does anyone own one of these on here or heard one?
Username: Th3pwn3r
Post Number:...
Post Number: 6200
Yea...I installed one of those and they're decent amps. Just make sure not to send it a clipped signal from a head unit because it will fry. Anyhow, I installed one of those amps paired up with CTMike's TC-9 and it gets pretty loud in a 2003 Monte Carlo for being a single 12 on 1k rms. For the money it's not a bad amp, how much are you paying by the way?
Post Number: 63
i already bought it. it was 290. brand new. i thought that was cheap.
Post Number: 64
and how would the head unit give it a clipped signal. sorry im a noob.
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 927
if you turn the volume up too much. just because the volume can go up to 60 or whatever it is that dosent mean its going to be a clean signal. turn it up to around 70-75%. so like 35-40 probobly.
Post Number: 65
ohh alright. yeah im never going to turn it up to 60 anyways.
Username: Th3pwn3r
Post Number:...
Post Number: 6202
http://bcae1.com/
Post Number: 66
so it says if i give the amp its full power. i couldnt go past 1/2 volume? right?
Post Number: 67
does anyone else own one of these?
