Amp rack?
Username: Pbplayer05
Carroll, Iowa
Post Number: 150
well right now i have the amp mounted to the back of the box but what would be better my back seats fold down so would it be a good idea to put it on my seat or would making an amp rack be better?
Carroll, Iowa
Post Number: 151
anyone have any ideas i just want a cleaner install
Username: Carguy
Post Number: 6742
Most install the amp on the back panel of the rear seat. Some mount it on the side, while other make their own rack. The choice is really up to you.
I have mine installed in the spare tire space. Why carry a spare when you can get an inflator in a can for $10? It is much lighter and saves on gas.
Username: Nd4spd18
Northwest PA
Post Number: 4486
Amp rack would be best. Back of the seat is most common.
Carroll, Iowa
Post Number: 152
well i dont have that much room so how would i go about an amp rack it would bein a 1995 monte carlo/ also ive never done the carpeting before like if i would carpet the amp rack or my box how s that done
Username: Nd4spd18
Northwest PA
Post Number: 4490
If you don't have much room then back of the seat is probably the way to go. Thats how mine is........
Carroll, Iowa
Post Number: 153
k thanks
