Username: Snw7619 Bahamas
Post Number: 50 Registered: Oct-06
Sunday, December 09, 2007 - 02:30 GMT i messed up my antenna setup setting for sat#110 please post the correct settings please im getting no signal from pansat 2500>2700 for sat#110???? lnb type-? LNB local-freq-? 22khz-? diseqc-? legacy sw? Skew-? TP-?
Post Number: 51 Registered: Oct-06
Sunday, December 09, 2007 - 02:33 GMT please somebody help me out!!!!
Username: Jagr1234 Post Number: 31 Registered: Nov-07
Sunday, December 09, 2007 - 02:34 GMT i think you reset rcvr to default setting and all will reset
Post Number: 52 Registered: Oct-06
Sunday, December 09, 2007 - 02:39 GMT um but wont that knock out all my sats also im no good with this stuff someone else programms it for me
Post Number: 53 Registered: Oct-06
Sunday, December 09, 2007 - 02:42 GMT can u just tell me what yours says and ill fry that
Post Number: 54 Registered: Oct-06
Sunday, December 09, 2007 - 02:44 GMT why does it say Skew -45?
Username: Jagr1234 Post Number: 32 Registered: Nov-07
Sunday, December 09, 2007 - 02:47 GMT do a factory reset of your recevr. your bin will not be deleted. then do blind scan of needed sats
Post Number: 55 Registered: Oct-06
Sunday, December 09, 2007 - 02:47 GMT whats gonna happen whe i default settings my cloned 2500>2700 pansat??????????????????????????????????????
Username: Jagr1234 Post Number: 33 Registered: Nov-07
Sunday, December 09, 2007 - 02:49 GMT your bin and conversion are unaffected
Post Number: 56 Registered: Oct-06
Sunday, December 09, 2007 - 02:50 GMT do u mean Default setting om Main menu because ive done that before and lost my sats and channel list.........
Username: Jagr1234 Post Number: 34 Registered: Nov-07
Sunday, December 09, 2007 - 02:52 GMT do blind scan 110 and 119
Post Number: 57 Registered: Oct-06
Sunday, December 09, 2007 - 02:54 GMT ok i did that now what do i do??????????? it say all channels have been deleted
Post Number: 58 Registered: Oct-06
Sunday, December 09, 2007 - 02:54 GMT how?
Post Number: 59 Registered: Oct-06
Sunday, December 09, 2007 - 02:55 GMT i dont see 110 or 119
Username: Jagr1234 Post Number: 36 Registered: Nov-07
Sunday, December 09, 2007 - 02:56 GMT do power scan of 110 and 119
Post Number: 60 Registered: Oct-06
Sunday, December 09, 2007 - 02:58 GMT it says sat-45?
Post Number: 61 Registered: Oct-06
Sunday, December 09, 2007 - 02:59 GMT ok new sat is 110 power scan is on
Username: Joeturn Post Number: 25 Registered: Apr-06
Sunday, December 09, 2007 - 03:03 GMT The factory default will definately erase all your settings and mess up your channel list!! lnb type-? standard LNB local-freq-? 11250 22khz-? off diseqc-? off legacy sw? none Skew-? N/A TP-? BLIND SCAN Afterwards you will most likely have to delete all your duplicates if your particular??
Username: Jagr1234 Post Number: 37 Registered: Nov-07
Sunday, December 09, 2007 - 03:03 GMT insert new satellite with these values degree - echo 119 lnb config - 11250 symbol range - full polarity - all scan -all scan degree - echo 110 lnb config - 11250 symbol range - full polarity - all scan -all scan
Username: Jagr1234 Post Number: 38 Registered: Nov-07
Sunday, December 09, 2007 - 03:04 GMT ok you found it. so you wont need these values then. just edit channels with remote when done.
Post Number: 62 Registered: Oct-06
Sunday, December 09, 2007 - 03:07 GMT its seems to be stuck on 10%
Username: Jagr1234 Post Number: 40 Registered: Nov-07
Sunday, December 09, 2007 - 03:09 GMT takes a while to complete...10-20 mins per sat
Post Number: 63 Registered: Oct-06
Sunday, December 09, 2007 - 03:13 GMT ok im puting that info in now try it again
Post Number: 64 Registered: Oct-06
Sunday, December 09, 2007 - 03:14 GMT r u able to get the boxing on your sat?
Post Number: 65 Registered: Oct-06
Sunday, December 09, 2007 - 03:15 GMT it said 19 transponders found now its scan channels i think
Username: Jagr1234 Post Number: 41 Registered: Nov-07
Sunday, December 09, 2007 - 03:15 GMT still will take more than 1/2 hr to scan both sats. did any channels show as found on earlier scan?
Post Number: 66 Registered: Oct-06
Sunday, December 09, 2007 - 03:17 GMT is power scan a blind scan?
Username: Jagr1234 Post Number: 42 Registered: Nov-07
Sunday, December 09, 2007 - 03:19 GMT yes
Post Number: 67 Registered: Oct-06
Sunday, December 09, 2007 - 03:19 GMT 00: 1E 19 DA 0A DF 23 D5 2F 90 B2 73 8B CC E1 9C 34 (active) is this latest codes for pan 27 clones?
Post Number: 68 Registered: Oct-06
Sunday, December 09, 2007 - 03:21 GMT first time i didnt do it correct its scanning 26% now and has some channels so far
Post Number: 70 Registered: Oct-06
Sunday, December 09, 2007 - 03:25 GMT still on 26%?
Post Number: 71 Registered: Oct-06
Sunday, December 09, 2007 - 03:27 GMT should i cancel it????
Username: Jagr1234 Post Number: 43 Registered: Nov-07
Sunday, December 09, 2007 - 03:29 GMT it takes a long time. you say it did pick up some channels right?
Username: Jagr1234 Post Number: 44 Registered: Nov-07
Sunday, December 09, 2007 - 03:30 GMT if this doesnt work for you may need to get channel master and load a channel list.
Post Number: 72 Registered: Oct-06
Sunday, December 09, 2007 - 03:31 GMT yeah it says tv-82 radio-2 but its been on 26% for about 20 minutes im doing sat 110 first is this okay?
Username: Jagr1234 Post Number: 45 Registered: Nov-07
Sunday, December 09, 2007 - 03:32 GMT sounds like its working. there is only so much you can do with a remote.
Post Number: 73 Registered: Oct-06
Sunday, December 09, 2007 - 03:32 GMT thats wha i was asking u because i tryed this before and it didnt work-channel master how?
Post Number: 74 Registered: Oct-06
Sunday, December 09, 2007 - 03:35 GMT still 26%
Username: Jagr1234 Post Number: 46 Registered: Nov-07
Sunday, December 09, 2007 - 03:38 GMT hook recvr to pc and get channel master off the web ...somewhere....get a channelist. load channel list on pc and write to stb you also could get "dido smith" channel list and load 110 and 119 lists.
Post Number: 75 Registered: Oct-06
Sunday, December 09, 2007 - 03:41 GMT whats better receiver to get a viewsat platumm or a pansat 3500????????????????????????????????????????????????????????????
Post Number: 76 Registered: Oct-06
Sunday, December 09, 2007 - 03:42 GMT im trying 119 now
Post Number: 78 Registered: Oct-06
Sunday, December 09, 2007 - 03:50 GMT 119 is 26%%% also???
Username: Jagr1234 Post Number: 47 Registered: Nov-07
Sunday, December 09, 2007 - 03:52 GMT sounds like it isnt working. you may have to load a channel list. it should blind scan though. you can start over again too.
Post Number: 79 Registered: Oct-06
Sunday, December 09, 2007 - 04:26 GMT 119 is still only 31% 30 minutes into scan.
Username: Jagr1234 Post Number: 50 Registered: Nov-07
Sunday, December 09, 2007 - 04:37 GMT its still going up. is real slow though
Post Number: 81 Registered: Oct-06
Sunday, December 09, 2007 - 04:37 GMT i cancel it only got some of the channel but hell yeah i got the boxing match ppvon now so thanks should i just re-scan 110-119 sats later to get all other channels 110 only went 26% and 119 sat went 31% so many channels are missing>
Post Number: 82 Registered: Oct-06
Sunday, December 09, 2007 - 04:38 GMT the reason for all this was trying to figure out how to scan sat to get channels that were not working so to get ppv boxing to worked for now
Username: Jagr1234 Post Number: 51 Registered: Nov-07
Sunday, December 09, 2007 - 04:39 GMT yup need full scan for both....have it scan while you sleep. at least one will be done by the am. shouldnt really take this long from my experiences
Post Number: 83 Registered: Oct-06
Sunday, December 09, 2007 - 04:41 GMT what kind of cable do i need to connect pansat to pc? s-video cord?
Username: Jagr1234 Post Number: 52 Registered: Nov-07
Sunday, December 09, 2007 - 04:43 GMT i use rs-232 serial 5 bucks
Username: Jagr1234 Post Number: 53 Registered: Nov-07
Sunday, December 09, 2007 - 04:44 GMT it would be better to just make this one you have work other than buying a new recvr with the current amount of ecms
Post Number: 84 Registered: Oct-06
Sunday, December 09, 2007 - 05:02 GMT yeah i guess but i normally have someone programm this for me but now he not programm 2500/2700 clones anymore only 3500's or viewsats
Username: Jagr1234 Post Number: 55 Registered: Nov-07
Sunday, December 09, 2007 - 05:03 GMT its easy just start searching and reading. how to's are out there.
Username: Jagr1234 Post Number: 56 Registered: Nov-07
Sunday, December 09, 2007 - 05:05 GMT your getting ripped off if your paying someone.
Username: Sara1 Post Number: 14 Registered: May-07
Sunday, December 09, 2007 - 07:23 GMT I just installed a Pansat 9200 and a Fortec antenna. I am not able to get more than 25% signal strength. I used a Accutrac 22 Pro dish aligning tool. There is nothing obstructing the dish. Can anyone help, please? Thanks.
