Bronze Member Username: Sara1Post Number: 15 Registered: May-07 | I just installed a Pansat 9200 and a Fortec antenna. I am not able to get more than 25% signal strength. I used a Accutrac 22 Pro dish aligning tool. I tried for more than half a day, but nothing! There is nothing obstructing the dish. Can anyone help, please? Thanks. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1770 Registered: Sep-06 | what sat are you pointing at? |
Bronze Member Username: Sara1Post Number: 16 Registered: May-07 | Intelsat America 8. |
Bronze Member Username: Sara1Post Number: 17 Registered: May-07 | Imeant Intelsat America 5 |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1771 Registered: Sep-06 | use that site, play with tilt and east-west and you will get it. I cannot at this time give you a accurate reading from my 31" we have storm's here and mine is having some rain faid. |
Bronze Member Username: Sara1Post Number: 18 Registered: May-07 | Thanks! Why isn't Intelsat America 5 or Telstar 5 listed in the list of satellites in the link you gave me? (I want to get the ethnic channels) |
Bronze Member Username: Jack_meoffPost Number: 40 Registered: Nov-07 | Get your 25% signal back. Rotate the lnb to either the left or the right, depending if the signal gets higher or lower. Naturally, you want to rotate the lnb in the direction which raises the signal. Once you have peaked the signal by rotating the lnb, then try moving the dish again to optimize your signal. That should do the trick. |
Bronze Member Username: One_eye_jackPost Number: 80 Registered: Nov-07 | The name was change to Galaxy 25 @ 97. http://www.lyngsa t.com/galaxy25.html What is the size of your dish and type of the LNB? |
Silver Member Username: Oleg1474Florida Usa Post Number: 504 Registered: Aug-06 | Att. (EURO/ECM666) coming soon !!!!! |
