Viewsat ultra help
Username: Shanec
hello, i have two view sat ultra recievers. i put a new program file on one of them and it worked when i put it on the other receiver and the power went out and wont come back in, there are four lines across the receiver screen. Is there are way to fix this or is my reciever done for.
Thanks for your time and help
shane collins
Username: Shanec
any help would be appreciated guys
thanks again
Username: Dimwitt
Post Number: 277
try loading the factory bin
or maybe this
C/P
how to clone 2 viewsats
For use in cloning one ViewSat to another.
a. Connect the "Master" ViewSat to your TV; Power switch "ON"
b. Connect the "Clone" to the wall power; switch Power "OFF"
c. Connect the "Master" and "Clone" ViewSats using a NULL MODEM cable
d. MENU--INSTALLATION--RECEIVER UPGRADE--ALL INFORMATION
e. "OK" and the "MASTER" ViewSat sets up to send data to the "Clone" ViewSat
f. Turn the "Clone" ViewSat's power switch to "ON" and the transfer begins
NOTE: AFter the transfer is completed, the "Clone" ViewSat needs up to 1 minute to process the transferred data.
Watch the Front Panel on the "Clone" ViewSat.
"inst" will be displayed for ~ 15 seconds
"DONE" will be displayed for ~ 10 seconds
REBOOT will occur automatically without user intervention " on " will be displayed during reboot
"0 0 0 0" will show when the "Clone" has finished--no more than 1 minute after data transfer
You may now Power "OFF" the "Clone" ViewSat, disconnect the NULL MODEM cable and go use your new Clone ViewSat
Username: Shanec
alright i will try that second thing thanks for your help
Username: Dash
Post Number: 7
Channel list for viewsat ultra
