Problem loading latest bin into XTREME
Username: Andruxa
Hello, fellow testers,
I am stumped. Got new bin, and when I load it, receiver does not want to install it. Upload goes to 100% and then is simply stuck. Usually display would flash as "dOUn." while dowloading, and then say "inSt.", then reboot, and go back to 00:00 time.
Now, it simply hangs at 100% on computer monitor, and stb display does not flash during upload, but randomly displays one of the 4 letters in word down.
I have tried another NULL cable, I have tried loading factory bin, I have tried factory reset x3, I have tried file from another source alltogether (to eliminate possibility it was corrup), and I have also eliminated the possibility that stb is a clone - it is as real as XTREMES get.
Any suggestions?
Username: Ke5aqn
Post Number: 1711
did you reboot the computer?
Username: Hi09
Post Number: 41
which bin are you loading anywyas none of them work right now
Username: Donnie1973
Post Number: 2196
huh?? I must be watching my imagination. :-)
Username: Ke5aqn
Post Number: 1718
The newest bin for that receiver is at TOTAL for you to download.
Username: Tomdamang
easy.
press the power button your reciever.
Username: Tomdamang
or,
use the cable that came with the reveiver.
a regular null cable will not do it.
Username: Andruxa
Figured it out. Laptop does not bring the port back online after going to power saver mode (sleep, hybernate, etc). Reboot fixes it, after suspend/hybernate/sleep the same problem again, and power cycle fixes it once again.
Username: Oleg1474
Florida Usa
Post Number: 496
Att. (EURO/ECM666) coming soon !!!!!
