use hex editor and just change 3643 and 5648 then run default threw the the 5681 witch will zero it out put it in the stream and ya have bev wide open. works for vs and cw. any questions please dont ask ive done it but wont do it again. this is just for educational purposes only
john so what the hack of coming saying what u did if u dont wanna help . it called you are full of shitttttttttttttttttttttttttt. if u dont wanna help keep it for your fuckingggggggggggg sself
Even if it works to use the hex editor to modify the bins, it is really a bad idea. Chance is high to mess up your stb. Let somebody else to take the risk instead of your $150 box.
I was refering to John Kratz mentioning on the hex editor and cs and cw.
yeah i was willing to try it even if it f*uck my receiver. but to try what . he gave me no clue . he is talking abouyt 3643 and 5648 it means nothing if he does not say how we do it .
it's very frustrating when u keep up waiting for a bin every fu8CKING DAY .
HONESTLY I DONT CARE ANY MORE ABOUT THIS FTA . IT SOUND LIKE NEAR THE END.
coder they wont keep up with this . so they will let fta down , tha's what i think but i may be wrong .
