Help with building a custom amp rack
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J... USA
Post Number: 698
Ok I'm feeling like doing something productive I want to build a amp rack. So if any1 can help I would love it ok my questions are
1. What kind of wood to use.
2. Good program for helping me do this.
3. Will the amps function correctly if there are setting at an angle facings the front of the cabin.
4. And will the amps overheat if I set them in flush in the amp rack hiding all except the top. Maybe even putting a lid over the top with hinges to open and close as I please. Any help or tips guys?
-apem
Post Number: 15992
1. come on you should know this.
2. come on you should know this.
3. come on you should know this.
4. come on you should know this.
Username: Vtouch06
Q-TowN, PA
Post Number: 42
haha^^^
Username: Jtown
Team Revolution, Texas
Post Number: 1061
same 3/4 mdf, or smaller, use the scrap...you don't need a design program, just cut out whatever shape you want the amp(s) sitting on and that's it. as far as sitting flush, make sure there is airspace between the flush plate and what the amp is sitting on for heat dissepation (spl check), maybe even drill some holes down the side of what essentially will be a box if you want it sitting flush, also for letting heat out and away from the amp. don't hang your amp upside down and you will be fine.
Post Number: 699
Mdf?? And actually I think I want to go all out with plexi glass and neons
Post Number: 700
Iight I know nothing about plexi glass any1 have an idea of how expensive it is and what kinda glue and nails to use. And is there a special tool to cut plexi glass
Username: Vtouch06
Q-TowN, PA
Post Number: 43
mdf= Medium-density fiberboard, lol you should know dwight you was at woodlawn's that day i saw you, and plus thats what your box is made out of...lol
Username: Jtown
Post Number: 1064
did you seriously just not know what MDF is.....????
all plexi will cost you, time and lotta money
Post Number: 701
I kno but your amp rack doesn't have to be made out of what your box is. I didn't think so I thought their might be a cheaper wood to use or something or a wood tht dissapates heat better or something. I'm not tht dumb I was just thinking 2 hard
A pic is worth 1000 posts!!
Post Number: 11535
Expensive? Yup. Where I bought mine:
http://www.professionalplastics.com/cgi-bin/pp.pl?pgm=co_disp&func=displ&strfnbr =3&prrfnbr=100409&sesent=0,0&search_id=82085
And we've all seen this guy's install. He used wood and lighting on his amp rack and it came out well I thought.
http://www.icixsound.com/vb/showthread.php?t=18078
Username: Jtown
Post Number: 1065
you want hard, you don't want the amp rack flexing at all...
Username: Jtown
Post Number: 1066
gawd that's a lot of wire...
Post Number: 702
Man I know what mdf is where did you get the impression tht I didn't?? I just thought something might be better for this project than plexi glass. Ok no plexiglass!
Is there any fans tht would be good for this?
-apem
Post Number: 15994
if you want a clean looking rack, go the fiberglass route. its a lot of work but looks nice if you paint it right.
unless you want your car to be all flashy, a simple amp rack that is very practical is the best route. what i mean by practical is, you can get to the settings on your amp without taking the amp out.
clean up the wires very nice and you are all set.
Username: Jtown
Post Number: 1068
you really won't need fans unless you are just pounding the sh!t out of your equipment all the time, and you have enough room for heat to get move around and hopefully get out of the small enclosure your amp(s) will be in if you are setting it flush
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 44
cuz thieves said "same 3/4 mdf, or smaller, use the scrap" and then in response to that you said "Mdf??" with question marks like you didnt know what it meant, thats what gave us the impression. lol
Post Number: 11536
Actually plexi is far stronger than MDF on a thickness to thickness comparison. Also FAAAAR more expensive. If you want the bling and have the jingle why not the plexi? Just be careful with the cuts. If you plan ahead have the manufacturer cut them to fit. They're pretty precise and you won't be taking any chances on your own.
Do you have the greenbacks?
Username: Jtown
Post Number: 1069
^x2
Post Number: 11537
When I ordered the plexi for my Q box I ordered a specific size and it came damn near perfect. I mean less than a 1/32-1/64th of an inch tolerance. I built my box around it instead of cutting the piece.
I paid over $30 for a 1/2" thick piece 12" X 16".
It's solid as a rock.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 46
damn thats crazii ^^^
Post Number: 11539
To me, worth it.
Post Number: 704
No I don't got the greenbacks lol but ima do mdf and its gona be a sweet as mdf rack ima blow you guys away I'm good at this kinda stuff once I get the basics down which I learned from woodlawn. I'm gona be heading to lowes 2mrw. How much is mdf roughly.
Post Number: 11541
$20-$25 a sheet?
Username: Jtown
Post Number: 1070
$13 for a 4' x 8'
here is my "flush" I'll be adding more bracing and a double baffle on top of the back of the box to reduce vibration drastically.
Username: Jtown
Post Number: 1071
Paul, where do you shop? d@mn, lol
Post Number: 11542
$13 a sheet???!!!
Username: Jtown
Post Number: 1072
I spent almost $30 last time, but I got some screws, wood glue, and rubber washers..lol
Username: Tejcurrent
Post Number: 913
Pauls right. It was $22 and change at lows for a full sheet a month or two last time I priced it.
Post Number: 11543
Mine was at least $20 at the Lowes.
Post Number: 11544
I'm guessing prices are different locally from place to place......
Post Number: 705
What would be some good tools for this I know I need a jigsaw and what else.
Username: Jtown
Post Number: 1074
sander (or rasp...lol), power drill, or carpenter's nail gun, circular saw
Post Number: 11545
Router if you're gonna round off the edges. Belt sander to take off rough edges. Drill bits to drill and counter sink the screws, I like the counter sink bits as they do two jobs in one. Clamps, squares, ect......
And just one word of advice, ok maybe two, don't rush and keep a neat/safe work enviornment.
Post Number: 706
How much those cicular saws be goin for? Man I'm super excited I can't wait to start on this I'm gona have u guys jaws dropped I might even be gettin some orders in haha
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 49
lol, arent you suppose to be saving for ur DD's and HO alternator dwight? jw
Username: Jtown
Post Number: 1076
yeah, good luck getting audio equip if you're gonna have to buy all these tools...lol
Post Number: 707
Yea I got 140 saved up so far for my ho alt I'm the type I need 2 buy something for myself every now and then and I haven't for a while so I'm going to be spending some of my check on this stuff. So I got 360 to go for my alt. These bills are kickin my azz.
What is countersinking screws?
Post Number: 708
I'm just gona buy the wood and cut it for now since I alreadii have a jigsaw at home I have a whole bunch of my step dads tools at home I gota look and see what's down their since he no longer lives with us.
Username: Jtown
Post Number: 1078
use the circular saw to cut the big pieces, and teh jigsaw to cut the detailed/smaller pieces....countersinking prevents wood splitting and allows the screw to go in easier, plus it makes the screws sit flush.
Nail gun FTW!!!
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 50
sh*t...id want ma subs r HO alt 1st b4 spendin money on an amp rack lol
Post Number: 709
Man 20 or 30 bucks aint going to destroy my savings I'm not taking out of my savings. The anticipation of getting this is killing me so I'm going to make the amp rack to kill some of my impatience
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 53
haha....aight man....
Username: Skibum12189
Cleveland
Post Number: 2142
http://i183.photobucket.com/albums/x228/caldapal08/DCP_4114.jpg
i suggest just buildin you box and playin the amp rack by ear...i built my box and then just rolled with it and i think the amp rack turned out rpetty good..
Username: Jtown
Post Number: 1094
never disappointed when I see that pic cal:-)
Username: Kyle_lowe
Post Number: 719
133 pictures of the install on that link
but i could have miscounted
Post Number: 710
Thts nice! Are those sd2.5?
I think I'm going to go on an angle aproach like whoever it is tht posted the picture of the RD amp 1750.1 I think. And I think ima paint it rather than carpet it I'm good at painting so ima go with tht thanks for the input guys anyting else ill post a picture of my plan for it later on
Post Number: 711
Hey cal what are those block things next to ur amp?
Username: Philly306
BUILT NOT BOUGHT, North carolina
Post Number: 620
those look like crossovers. and no in cal's pic those arent sd2.5s. those are SI bms and looks like a nine.4 and a nine.1 if im not mistaken
looks nice too
