Bronze Member Username: BaalpeteorPost Number: 28 Registered: Oct-07 | is it the door trigger wire? or maybe door pin.. or are they the same? mine locks and unlocks.. but I have a blue wire that is for the doors.. b/c when i attached to the inside light... it said "please close the door" (the light had a hot wire to it) and when it was armed it went off. I have a 94 sunbird and all I see is door trigger, whih is white (-) (http://www.the12volt.com/installbay/alarmdetail/1891.html) |
Bronze Member Username: BaalpeteorPost Number: 32 Registered: Oct-07 | n/m seems no one here knew so I just looked around and found it. Maybe i should be giving help here :-O for future reference ona 94 sunbird 2 door, its green with black lines |
