I'm confused
Username: Kalash94
Post Number: 15
can i enter manually any keys on my megasat4000 or do they have to be megasat4000 keys?
Username: Ke5aqn
Post Number: 1761
entering keys will NOT get PPV-Movie, ethnoc Channels to work at this time.
Username: Kalash94
Post Number: 16
i'm just trying to get the premiere channels UNSCRAMBLED and can u give me a bit more detail
by the way thanks for ur answer again ur the only guy helping me out here
Username: Mclinkus
Post Number: 187
megasat does not have a brand of particular keys that the own. to make that box work
you may need to update the dishn3t work keys evrey so often .. but
like tester said that wont get your p0rn back today.
sorry.
Username: Ke5aqn
Post Number: 1762
I know you are trying to get channels unscrambled. As of now I cant find a new bin to fix your receiver. I would strongly suggest you get a better receiver vewsat plat light is on ebay for around 130 shipped.....great suppport and updated fast
Username: Kalash94
Post Number: 17
do you if i can get it converted to a better receiver?
and what will the dishn3t work keys do?
Username: Mclinkus
Post Number: 189
that reciver is not converatable. that i know if.
its obviosuly a clone of somethign. but im not sure what..
dish keys will do nothing for you right now
did you look at the megasat area??
id recomend at least looking at that..
im sure other sites may have those types of areas also. im jsut not sure wich one just in case you rnt comfortable visiting the fastest growing fta site on the net.
'link
Username: Kalash94
Post Number: 18
i've been on ur site but there are no threats in the megasat area
by the way megasat 4000 is a clone of cools@4000 i think
Username: Saqeeb9000
Post Number: 566
kalash megaset 4000 is same as cooltec reciever.. on their website they have cooltec.. bins its same i have Koolsat 4000 pro (clone of cs)... and its same .. go to menu sys inf.. and check the file it should be from norw grou.. and it says x-oclone.. thats what ftaview.com has their on website..
by the way we are still waiting for new bin for cooltec or megasat (same).. last bin was out couple of weeks ago..
