Bronze Member Username: Book77Post Number: 100 Registered: May-06 | Just got a Sonicview 4000 Boot loader 01.03 Main Software 01.58 I hAVE NO IDEA what to do now. can i just upload the new bin I dont see keys or anything Help please |
Silver Member Username: Saqeeb9000Post Number: 623 Registered: Oct-07 | go to and then download new bin for sonicview 4000. if it comes with usb slot.. just download the bin on usbdrive,extract it,and then just plug in to reciver.. it will automatically comes up on ur tv and will ask you to press some button to download tv...just press the button and enjoy... |
Silver Member Username: Book77Post Number: 101 Registered: May-06 | I took it out of the box and it had this software Boot loader 01.03 Main Software 01.58 Can i update to the new bin from this stage Or i do i need something else i dont see a key menu will that come after my first update is there a good dummies guide |
Silver Member Username: DimwittPost Number: 281 Registered: Aug-06 | https://www.ecoustics.com/electronics/forum/home-video/385534.html |
Silver Member Username: Book77Post Number: 102 Registered: May-06 | that does not answer my question . Can i update from this stage?? I dont see any keys nothing?? I dont see keys in user guide either My question with what my receiver came with can i Update |
Silver Member Username: DimwittPost Number: 283 Registered: Aug-06 | yes - update now key info will appear after the update |
Silver Member Username: Book77Post Number: 103 Registered: May-06 | thank you Tooter |
Silver Member Username: Book77Post Number: 104 Registered: May-06 | Tooter ; Do you know if this is factory software Boot loader 01.03 Main Software 01.58 |
Silver Member Username: DimwittPost Number: 284 Registered: Aug-06 | I don't own one www.sonicviewusa.com/support.html sv4000_factory_20061229.zip |
Silver Member Username: Book77Post Number: 105 Registered: May-06 | can anyone else verify that i can update from this stage . i am afraid of killing my new receiver |
