I have not used the yellow card for almost 1 year. I do not have the programmer for it. Please let me know whether it will work good or have the same ecm problem every week. Because i will have it programed from someone and i do not want o pay and after that same problem of ECM.
you will have to have new writes for most of the recent ecms. you will pay. or you learn how to do it yourself....instructions are out the if you look around
Yest i know that i have to pay or i can learn. The only thing bothering me is the ECM. In the FTA receivers they are changing the ECM every week. I have Cools*t and did not get the fix yet from last 2 weeks. If the yellow card is also having the same problem then there is no point of having it fixed. It will cost around $50-$65 to have it fixed. Please let me know what is best option???
Either wait for the FTA or have yellow card fixed?
Thanks for letting me know that both are effected by ecm. The thing is last year the when i have problem with fta i used the yellow card and it goes well for 3 months and after that i used the FTA. I thought may be the yellow will go good for sometime. Anyway thanks for letting me know.
card programming in general will probably occur and be usable for testing longer than these set top boxes will. it wouldn't be a bad idea to start learning with the card. an unlocked rom102 is worth about 250.
