nalin ,fta tester anybody yesterday i installed the new bin for pansat 2700a but acceident cause i had both the clone safe and the original one so i uploaded it to my reecvier it worked good for about 2 ahours then no power is there anything to do to fix it or it is garbage now
well you need to do whats called a jtag process, its a pain to do it. if you are not familure with that then you need to get professional help and if you are planning to spend money to get that jtag done(depends on your budget) then I would just get a new receiver. 2700clones are junk anyways.
