What's the best receiver to buy
Username: Navatkuli
Post Number: 9
I am planning to buy a fta receiver; what's the best receiver I can get around for $150
Username: Vhl71
Post Number: 88
CNX...(conaxsat) you can't go wrong with this beauty!!
Username: Pffft
Ya Right
Post Number: 263
and the next time you need a new truck go to the local ford guy and ask him what the best trucks are
Username: Extremex
Post Number: 26
LOL, good 1.
I would not buy anything til you see how thing are going to pan out with the new dynamic ECM's
Username: Mrsofty
Post Number: 13
I just Got a new buzz box at GetDss.com its an auction site.... but they had a cool*sat for $79.... now is a good time to buy if you have faith that all will be well. Good deals
Username: Ke5aqn
Post Number: 1585
Everone has their favorite it is alot like the chevy-ford-dodge argument. I myself have tested a coulsat, viewsat, and a pansat. You can find all the diferant Brands are about the same price.
I like the viewsat's better based on one feature they have that I have not found in any other receiver. The Viewsat's will Identify the Satellite the antenna is actually pointed at saving alot of time during install and every day use.
As far as antenna set up the best set up for FTA is a 31" dish, Motor, and proper lnb for DBS ( dn-bev ) and true FTA ( QTH-031 the best LNB ).....and your receiver
Their are 31 sat's out their with programing on them with over 2500 channels you can get with a clear sky and that set up......
Cost is around $150 and set up is very easy most times easer than all the switching required with using 2 dishes to just get a few DN or BEV sat's that MAY or MaY NOT have channels working at the time.
Username: Mclinkus
Post Number: 69
[link removed]
we have live discusion on whats happening
[link removed]
taran was just disscing this in the live chat box
Username: Ke5aqn
Post Number: 1588
Username: Extremex
Post Number: 28
Cooolsat and NFusion also identify sat. Most all newer box do.
Username: Brucester
Post Number: 718
TFT cw600p will also do the same thing i do not no how it works but it does and is very useful for moving the dish co viewsat is not the only box with that feture
Username: Donnie1973
Post Number: 2139
captiveworks I hear still have all dn channels..??
Username: Ke5aqn
Post Number: 1589
Thats cool I am glad some other box's other than Viewsat ID's the sats now. I expected others did you just never hear about it..
Post Number: 2144
i expect most do, even pansat, just not the low end 2700
Username: Ke5aqn
Post Number: 1590
I have a 3500sd right here and it does not.
Post Number: 2147
i expect the 9000hd does? lol
i know the sv, cw, vs, does, I thought the 3500 did, just figured the higher ends would have this.
Username: Ke5aqn
Post Number: 1591
I wish they did it sure makes them easer to use and install...so your not lost
like this guy was Upload
