New member Username: BombayPost Number: 1 Registered: Dec-07 | Friends, I am new to FTA and was wondering if CW3000HD is a good reciever to consider with Motorized Dish or a wave frontier totodial?. Are BIN updates easily available for CW3000HD? or should I start with a low end FTA reciever to begin with and progress? WHat are good FTA Recievers to consider? Considering all the chaos about the new ECM how does the future of FTA world looks to all you FTA vetrans? Peace |
Gold Member Username: RtapFL Post Number: 1288 Registered: Jan-07 | kp right now DISHNET does not offer that many channel for HD.bev offers more channels for HD.its not worth at this moment to get a hd receiver for dishnet.start off with a viewsat or sonicview. |
Silver Member Username: BrucesterPost Number: 700 Registered: Jul-06 | or go with a great box for around 100 can eazy to use great support and it is a captive works cw600p and for 20 dollars cheaper you can get cw600s but the cw600p got more to offer then the cw600s both got great support and both are eazy to us just buy and load newest bin out and watch tv in my eyes cw got best bang for your doller |
Silver Member Username: FrobiGuelph, Ontario Canada Post Number: 102 Registered: Aug-06 | I definately agree with Bruce. Easy, cheap and quick support. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 1509 Registered: Sep-06 | I would agree too. Go with a cheaper viewsat model for now. I like the viewsat better they will ID the sat their antenna is pointed at making it much easer to install and use. The best set up for FTA is a 31" dish, Motor, and proper lnb for DBS ( dn-bev ) and true FTA ( QTH-031 the best LNB ).....and your receiver Their are 31 sat's out their with programing on them with over 2500 channels you can get with a clear sky and that set up......This set up includes all of DN, all of BEV and ALL the True FTA sat's that are "in the clear" all the time no bin needed. Cost is around $150 and set up is very easey most times easer than all the switching required with using 2 dishes to just get a few sat's... If you decide to get the motor set up come in here before you start the install and I can give you step by step instructions on how to set it up in around 2 hours from unboxing the stuff to watching tv. |
New member Username: ExtremexPost Number: 7 Registered: Nov-07 | DN offers more HD then Bev. Especially if you consider all the local markets in HD that you would pick up. |
New member Username: BombayPost Number: 4 Registered: Dec-07 | Thank you all for your valuable inputs... I will go with a Cheaper reciever now & switch to HD as I have more experience & DN offers more HD programming THE FTA TESTER, I will definately contact you as I am planning on getting dish with Motor |
New member Username: BombayPost Number: 6 Registered: Dec-07 | How to get Updates for CW receivers are updates available for CW 3000? or only for non HD models? |
Silver Member Username: BrucesterPost Number: 712 Registered: Jul-06 | if you go to complete dot com you will see the filles and you need to by a nother piece for around 200 all fta hd boxes need this other pice to work some kind of moudgoulater |
Bronze Member Username: ExtremexPost Number: 13 Registered: Nov-07 | CW3000 HD is not your average STB. Its a PC base running Linux. So having knowledge of Linux is a plus, but not a requirement. Also to receive DN HD and any FTA box will require additional hardware. |
New member Username: BombayPost Number: 7 Registered: Dec-07 | I know Linux, but apart from that need to know as much details as u can provide, any links to other websites & the hardware that you are referring |
Bronze Member Username: ExtremexPost Number: 16 Registered: Nov-07 | F2ATV is has a section devoted to the box. The site is overloaded at the moment. I will try to find another site for you. |
Silver Member Username: DimwittPost Number: 266 Registered: Aug-06 | info on the box www.captiveworks.org/forum/index.php |
Bronze Member Username: RescateVENEZUELA Post Number: 28 Registered: Nov-07 | THE FTA TESTER, The best set up for FTA is a 31" dish, Motor, and proper lnb for DBS ( dn-bev ) and true FTA ( QTH-031 the best LNB ).....and your receiver I want to setup this, could you tell me where is the guide, Thanks |
Bronze Member Username: ExtremexPost Number: 18 Registered: Nov-07 | Why not start your own thread, rather than hijacking this one? |
Bronze Member Username: RescateVENEZUELA Post Number: 30 Registered: Nov-07 | Hijac king??? ooops, sorry |
Gold Member Username: NydasPost Number: 5696 Registered: Jun-06 | What do you think of this email I got today from totalfta? from TotalFta Admin < |
