Username: Mossok Post Number: 9 Registered: Feb-06
Wednesday, December 05, 2007 - 02:18 GMT is it possible the last bin file can burn my viewsat ultra after i programe no moore power ???
Username: Silverlion80 Post Number: 18 Registered: Nov-07
Wednesday, December 05, 2007 - 02:19 GMT what is the bin you used ?
Username: Mossok Post Number: 10 Registered: Feb-06
Wednesday, December 05, 2007 - 02:21 GMT the one on totalfta for viewsat ultra
Username: Silverlion80 Post Number: 20 Registered: Nov-07
Wednesday, December 05, 2007 - 02:26 GMT ok thats good but i am wondering if you got vs clone cause the one on totalfta is just for original ones only not good for clones
Username: Mossok Post Number: 11 Registered: Feb-06
Wednesday, December 05, 2007 - 02:30 GMT no its not a clone my friend got the same i bye 2 vs same place same time and you think its a clone that one thanks for your reply LEBANON
Username: Silverlion80 Post Number: 24 Registered: Nov-07
Wednesday, December 05, 2007 - 02:45 GMT i tryed to help but guess i couldnt SORRY
Username: Ke5aqn IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 1561 Registered: Sep-06
Wednesday, December 05, 2007 - 02:51 GMT Tell us...what is your set up and what is your receiver doing now...?
Username: Mossok Post Number: 12 Registered: Feb-06
Wednesday, December 05, 2007 - 02:58 GMT nothing no moore power i got dvd vs
I WILL FIND...
Post Number: 1566 Registered: Sep-06
Wednesday, December 05, 2007 - 03:02 GMT what was you doing when you lost power?
Username: Mossok Post Number: 13 Registered: Feb-06
Wednesday, December 05, 2007 - 03:05 GMT nothing i cant turn on
Username: Budgie123 Post Number: 25 Registered: Sep-06
Wednesday, December 05, 2007 - 03:06 GMT my vs clone was killed by the newest bin even I added the protective circuits(a few resistors and triode) and the new bios provided/suggested by the clone manufacturer/distributor.
Username: Mossok Post Number: 14 Registered: Feb-06
Wednesday, December 05, 2007 - 03:08 GMT i do you no its a clone
