Problems with my Pansat 2700A
Username: Dant208
Hi everyone. The problem that im having with my Pansat 2700A is that after a time its start saying "scamble or bad signal" in my PPV and some other channels for 3 to 5 minutes and then its start working fine again and a couple of hours later its start doing it again. If i need a new file please post where i can find the new file.
Username: Ke5aqn
Post Number: 1443
It seams to be a small bug in the receiver. Reboot it and see if that helps other than that just wait I am sure a new bin will be out sometime fixing little bug's like that. Before you ask NO I DO NOT KNOW WHEN...just enjoy free tv and wait.
Username: Machedonul
Post Number: 278
yea, there is definitely a bug in 225 bin
all my channels are struggling as well
Username: Nydas
Post Number: 5628
Julio Rivera : for the past 3-4 BINs on Pansat 2700 (and clones and conversions) there are freezes and glitches. They get reduced in frequency if you turn autoroll and autoTP off.
Even with the Autoroll off the ID 0101 and 0901 and C101 keys roll in MOST OF THE TIME, BUT NOT ALWAYS.
Username: Dant208
Thanks everyone.
