Username: Bbford Post Number: 6 Registered: Mar-05
Monday, December 03, 2007 - 02:48 GMT which loader do i use for viewsat ultra thank you.
Username: Psanand Oakville,
On
Cananda
Post Number: 23 Registered: Sep-06
Monday, December 03, 2007 - 02:50 GMT check totalfta.com
Username: Hshakarchi Post Number: 148 Registered: May-06
Monday, December 03, 2007 - 16:55 GMT if you have ultra why dont you use the USB stick to load your Bin
Username: Dude123 Post Number: 1404 Registered: Jul-06
Monday, December 03, 2007 - 17:40 GMT good point hanibal! All you have to do is tranfer the file in the usb that it came with using your computer and then transfer it from the usb to the receiver!
Username: Rtap FL
Post Number: 1264 Registered: Jan-07
Monday, December 03, 2007 - 17:49 GMT bob follow this link there u will find the loader u need.remember as stated from hanibal and the one it is easier to load by usb. http://ftabins.net/showthread.php?t=1096
Username: Bbford Post Number: 7 Registered: Mar-05
Tuesday, December 04, 2007 - 00:19 GMT Its not my box its a freind and he does not have the stick yet and as i am not that farmilar with it i did not want to talk any chances thanks for the advice.
Username: Buddho81 Post Number: 45 Registered: May-06
Tuesday, December 04, 2007 - 00:53 GMT with the usb drive you're not taking a chance...Its actually the easiest way to load a file onto an Viewsat Ultra! I have been using it for past 6months and I have never connected this to a computer! Good luck!
