All ports say 61.5
Username: Me_me
Post Number: 23
loaded vs2000 platinum file all ports say 61.5 west, do i need to load the factory file and the load the new file.
thanks
Username: Ke5aqn
Post Number: 1439
what "ports" please please explain this part
Username: Me_me
Post Number: 24
i have a view sat vs 2000 plat,
i have to hit fav to make it switch from 61.5w
to 119.0w and and when i loaded the file
it still auto rolling for 2 hours
need help fta tester
Username: Ke5aqn
Post Number: 1441
the receiver is looking at the wrong sat. adjust your antenna settings and all will ok.
Username: Me_me
Post Number: 25
when i put it on 61.5 it says 119.0 auto rolling
how. i tryed but nothing seems to work.
had to recever and when hooked up the other this problem came along both same boxes.
how to change antenna setting
Username: Me_me
Post Number: 27
when i go on channel 61.5 its says auto rolling
on 119.0w
Username: Ke5aqn
Post Number: 1444
antenna settings is menu, installation, antenna setup......
Username: Me_me
Post Number: 28
i went there when i go to ports it says all are
facing 1190w it wont find antenia 61.5
Username: Me_me
Post Number: 29
Username: Ke5aqn
Post Number: 1447
what is your antenna?
a dish 500?
a motorized dish?
14 dishes mounted to a brick wall?
Username: Me_me
Post Number: 30
dish network
14 dish mounted to a brick wall
Username: Me_me
Post Number: 31
i have two dishes one for 61'5 and one for 119.0w
on a brick wall. don't know exactly what it is.
Username: Ke5aqn
Post Number: 1451
Ok make sure in settings you have the correct settings entered for the ditec switch representing were the coax exit's the switch to the antenna for each LNB.
Username: Me_me
Post Number: 32
i also have two boxes both platinum, on the other box i have to hit fav to swith from one dish to the other, and also on that box i can't get it to get out autorolling.
Username: Ke5aqn
Post Number: 1455
are the box's both autorolling on all channles or just the PPV-Movie channles?
Username: Me_me
Post Number: 34
one is working fine
the othe other one has the problem.
thats the one with the fav list
Username: Ke5aqn
Post Number: 1457
get the channel list off of it useing the loader ((do you know how))and then factory reset it, put newest bin in, put channel list BACK in see what that does..
Username: Me_me
Post Number: 35
how do i take the channel list out, how to reset it.
Username: Ke5aqn
Post Number: 1459
Ok cool,
Its a little tricky to get a file from the receiver but can be done...
Must be able to have the receiver connected to a TV and the Computer Same time...
after conecting the receiver to the computer and tv turn on the receiver....hit menu, system information, receiver upgrade, move down to CHANNEL hit your ok buttion....a process bar will apear.....then on your computer open the loader and hit the STB--PC buttion the transfer will start......after both are done you can do the factory reset on the receiver then proceed with installing the newest bin . Then simply put the channel list back in the same way you do a bin file......here is a copy and paist of instructions for that...
LOAD VIEWSAT:
To load latest new program bin file
Connect a NULL MODEM cable (pins 2&3 cross) between the ViewSat and your PC. NO POWER to ViewSat yet.
Open "Loader2
Click "Open Files"
Browse to directory holding "Latest Program Bin.PGM", Click on it to "OPEN"
Click PC-->STB on your computer screen; then Power "ON" your ViewSat electric power (ON/OFF switch Platinum; plug in Black). You should see the File loading properly.
WARNING: DO NOT POWER VIEWSAT OFF UNTIL TOLD!
After file transfer is completed, the Front Panel will display: "inst" for 15 seconds while the software is being installed "DONE" for 10 seconds while the ViewSat does housekeeping chores next, the ViewSat automatically reboots.
The display will read "on" and when the reboot is complete, "0000?
You may NOW turn "OFF" the ViewSat and connect it to your TV and satellite dish cable
To load, sat file, channel list or Opkey. Follow the above procedure clicking on each file. The loader will put them in the proper place.
Username: Me_me
Post Number: 36
how do i reste i box
