Bronze Member Username: LionkingPost Number: 41 Registered: Jun-06 | I am trying to load the new225t bin but when i look into the sys information it still shows 224t. can somebody please help? |
Gold Member Username: NydasPost Number: 5591 Registered: Jun-06 | Obviously it has 224T and not 225T. Connect to your computer with a straight RS232 cable. To load CS_225T_lightning, you will have to first unzip the file, then use use either BL 1.4 updater or Chancy's own uploader (both are provided) and select BIN. Then select the CS_225T_lightning file. Turn on the receiver and as soon as "b" shows, click on Write BIN. Most people make the mistake here. |
Bronze Member Username: LionkingPost Number: 42 Registered: Jun-06 | thanks nalin but i have done exactly you have said it says that the new download is complete but when when i connect it back with the tv and check the bin it says 224t. May be i am downloading from wrong site |
Gold Member Username: NydasPost Number: 5596 Registered: Jun-06 | I trust you did allow the BURN to take place and waited for "ON" The system info should say Clone- Safe:75-225T_EUbX Boot ver : 75 02 Dec. 2007 Surely there is date on your system info. The file is from Fortec section of files at [link removed] |
Bronze Member Username: LionkingPost Number: 44 Registered: Jun-06 | thanks Nalin i thinks i was using different loader It worked with blacklist serial loader |
Bronze Member Username: Pike_376Post Number: 69 Registered: Nov-06 | please help me where can i get the j-tag file for a converted 2500A to 2700? I was loading the new bin file and my box went black. now it will not turn on there is nothing like it has no power |
Gold Member Username: NydasPost Number: 5612 Registered: Jun-06 | The zipped file has all the goodies in it - three loaders and the two BINs - one for jtag and one for serial load. CS_225T_Lightning_100t_Series_serial.zip Contents: 225,280 2500-2700 Serial Updater v1.0.exe 225,280 Blacklist Updater.exe 1,048,576 CS_225T_FS-LifeTime-Ultra - Flash 1(29LV800BTC) - JTAG.bin 1,107 CS_225T_Lighting series.txt 458,752 CS_225T_Lightning_100t_Series_serial.bin 630,784 FortecStarSTB.exe Avaialble at: [link removed] - files/Fortec [link removed] You need the jtag bin |
Silver Member Username: Pulp_fictionPost Number: 493 Registered: Nov-07 | Don't waste you time on here with the conversion question... The admin on this site the conversion Guru |
Gold Member Username: NydasPost Number: 5620 Registered: Jun-06 | Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. http://public.box.net/2500_full_kit |
