Pansat 3500
Username: Lizwakefield
Post Number: 28
I just bought a new pansat 3500 and i downloaded the latest bin 340 but all my channels have the wrong names where can i get a channel list and the chanel master or is there another way to fix this
please help
Username: Abj
Post Number: 450
what do you mean wrong names?
Post Number: 29
for example ppv its not called ppv its w somethign and lmn is called tqsq u know what i mean...seems like all the channel names are wrong
Username: Abj
Post Number: 451
may be you assigned wrong disq port..
what satellite are you getting?
110 and 119?
what is your antana sitting?
did you try switch
for example.. if your 119 disq is at 2 change to 1
if its at 1 change to 2
119- 1 110- 2 change it to 119-2 110-1
Post Number: 30
i am gonna try that..but i am pretty sure
i have the right disq port its 110
my 119 is not working for some reason.....i have two lnb but i can only get 110 i dont get any signal for 119
Username: Rtap
FL
Post Number: 1268
then your connection to switch may be wrong or your settings in antenna.check both
Username: Rtap
FL
Post Number: 1269
remember your switch has to be the correct one,u can not use any switch.
Username: Ke5aqn
Post Number: 1406
Liz,
I also have that receiver connected to a switch and 2 lnb's. I had the same trouble as you as far the wrong channels. The way I got mine working correctly is I would disconnect the switch and go straight from LNB to receiver, do a blind scan on that sat and then turn OFF receiver, change to the other LNB and scan that sat....then the receiver will have the correct channels from both sat's your can receive. Then you can connect the switch and set everything correctly and everything should work fine.
Username: Rtap
FL
Post Number: 1273
TFT thanks i learned something new today.
Username: Ke5aqn
Post Number: 1408
I even do that with the viewsat-motorized antenna set up when scanning a sat I turn off the Motor the stupid receiver kept moving the dish to another sat then scanning...
