Silver Member Username: Satgrl
Post Number: 826 Registered: Oct-07
Posted on is the the freeze fix has anyone tested it?...does it fix the micro freeze problem??...thanks SV4000_V0180P Micro Freeze update FIXED -------------------------------------------------------------------------------- SV4000_V0180P Micro Freeze update FIXED WARNING: Use all files at your own risk. Attachment Issues? SV4000_V0180P.zip (1.06 MB, 2891 views) |
