Dolby Digital on VS Pro
Username: Thadragun
Kingston, Ontario
Post Number: 19
How do you set up the dolby digital sound on Viewsat Pro? I have went to the av settings and turned dolby on, and I pressed the audio button on the remote and selected Dolby (shown as unknown) then there is no sound through my tv, or my Stereo. If I change it back then there is sound. Is there a special way I have to set up the receiver?
Username: Ke5aqn
Post Number: 1462
First and most importantly you have to be watching a channel that is broadcasting in DOLBY. I suspect that was all it was. Not all channels on DN or BEV and very few ( mabee 2 ) on FTA are in Dolby.
Go to mabee a PPV that is advertising it is in Dolby and see if it works......I have seen some on BEV that are but, not on DN at least with a FTA receiver...
Username: Thadragun
Kingston, Ontario
Post Number: 20
yup it was Oceans 11 5.1 dolby. Its on right now. Channel 353
Username: Ke5aqn
Post Number: 1464
well then just play with the setttings...mabe one small thing wrong with your set up
not much exparence with that sorry..
I would suggest you go to total and post this question in the section for your receiver you are more likely to find an answer form a user of that receiver their...
Username: Thadragun
Kingston, Ontario
Post Number: 21
thanks
