PANSAT 2700A
Username: Manny180
PR Puerto Rico
Post Number: 11
new file is posted at future fta site
Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 1081
yay!!
Username: Mclinkus
Post Number: 38
we have all the files that have been relased
at
[link removed]
Username: Vittu
Post Number: 61
Beware FLU to 2700. This file is for ORIGINAL Pansat Only. NO clone safe.
Username: Mufta
Post Number: 56
All PanSat files are out now...
Enjoy!
Username: Pathfinder191
Post Number: 234
ftaview has all older files. Don't even waste your time.
Username: Dude123
Post Number: 1381
Sam, go to future-fta.info for all the fixes....no need to register there righ now
Username: Shamhd
Post Number: 12
pansat2700a new fix working well
Username: Destine0429
Quebec Canada
Post Number: 317
Pansat 2500a converted to Pansat 2700a clone receivers....been confirmed by some at www.ftabins*net that the new
CS_225T_Light_100t
bin is up and running...
Username: Miamihitman09
Post Number: 30
Hello guys and girls, I got the new bin and installed them, but i still get to quality at all. I get about 79% level but not quality. What is wrong? I get to channel. thanks
Username: Ozziejatt
Post Number: 27
on my pansat i cant go beyond 406 to select channels like 188 or 177. channel like national geographc dont show/exist like it was before.
Username: Gupulamba
Brampton, Ontario Canada
Post Number: 23
hi i have a reciever which i cloned it from flu to pansat nnow i have loaded the CS_225T_Light_100t and when i go for a scan its 0 transponders i dont know why n ma dish its sayz is sat-45 and at zero degrees can someone help please nalin can u please help
Username: Ke5aqn
Post Number: 1435
Eric, You simply have a antenna problem. It is more than likly in your antenna settings of the receiver.
OzJatt,
You just need to rescan the sat...eather make sure you have every transponder on the satellite you are gonna scan or do a blind scan.. then all channels will come back..
That is why I always take the channel list off the receiver before I install a new bin then after installing the new bin put the channel list back in the receiver. With over 10 sat's and 1500 channels it takes A LONG LONG time for me to rescan the birds.
Username: Gupulamba
Post Number: 24
Fta tester can u please help me}
Username: Ke5aqn
Post Number: 1436
I forgot this too
Always Always Always have "auto update transponder' OFF reason is:
IF your receiver for whatever reason tries to look for a channel on the WRONG ((you settings are wrong, your motor went to the wrong sat, etc ))sat it will think the transponder needs to be rescanned THAT will make you LOSE channels....
Username: Ozziejatt
Post Number: 29
good idea FTA...you are the best.
as i asked u on the other post if i do factory reset that do i need to install bin file again and then do a sattellite scan?
Username: Flipherlid2
Having download problems with pansat 2700 A original. I keep getting error message loader can't find file.I haven't had this problem b 4 with other downloads. N e ideas on what the problem might b? I have extracted the files also b75 file 225
Username: Nydas
Post Number: 5646
Hope you are using Loader 27.02
