Need help FTA TESTER/Nalin can u help me
Username: Pike_376
Post Number: 64
I need to tak emy pansat 2500a that I converted to a 2700 back to a 2500a and start over. Which files do I use to take it back to an original 2500a and then what do I have to put into it to make it a 2700. Please tell me all file names that have to be put in. I have all the files on my computer just aint sure which I need
Username: Nydas
Post Number: 5593
2700 to 2500 via serial port.zip
You will find it at
[link removed]
[link removed]
http://www.dssrookie.com
Username: Ke5aqn
Post Number: 1401
Lots of work to get a older receiver to work 1/2
new viewsat and pansats are around 120 shipped now.
Username: Pike_376
Post Number: 66
just load the file using blacklist updater and it will be back to a 2500
if so what all files have to be put in to convert back to 2700 when I get to the original 2500
Username: Pike_376
Post Number: 67
i am just having a few probs with it and would like to take it back to a 2500a so that I can start over and reconvert it to a 2700 so that it will work right.
