Sonicview Fixes - DSS World
Username: Asharfi
Post Number: 1508
All the Sonicview ECM fixes are out and posted at www.dssworld.co.nr. Most of the DSS website are going down because of the traffic, so that's why I've posted the latest Sonicview fixes at www.dssworld.co.nr, just in case if u need them .. enojy ....
Username: Newbie777
Post Number: 21
hey AV, u were gonna screw FTA and rent some po*rn yesterday, weren't you bro? :-)
Username: Satgrl
Post Number: 794
has anyone tested it?
Username: Asharfi
Post Number: 1509
FUN FTA,
Buddy, I don't have Sonicview units ... I run my own small FTA community and posted new fixes for FTA users ... I have FLUs ... I'll wait for the bins ... lol .... I was soooooooooooo pissedd off yesterday ... but now .... i m kinda excited .... and feeling good ... lol .... satgrl .... bins r working good
Username: Satgrl
Post Number: 798
thnxs AV
Username: Satgrl
Post Number: 799
AV i downloaded thanks it was very easy all i did was register under less den a minute..lol...and i got it...anyone tested it let me know if its wokring
Username: Newbie777
Post Number: 22
good AV, u r always a helping guy here man. Appreciate your posts dude.
Username: Asharfi
Post Number: 1510
Bins r working ... read the readme file included
Username: Satgrl
Post Number: 801
yes i read it...;)...thnxs...is it tested by coders right thats why it says that?
Username: Asharfi
Post Number: 1511
yep .. all good and tested
Username: Satgrl
Post Number: 804
YAY IM SO HAPPYY!!!!!!!!!!!!!!!!!!!....AV remember when i killed my pansat 2500 when i was converting...lol..im always scared now before i load a new file..
Username: Asharfi
Post Number: 1512
So, all channels are working? Lucky u ... I have to wait for my FTA unit
Username: Sjain80
Post Number: 92
AV.. I have question for you (for flu). I had changed my flu to pansat a while back. It was working smooth and never had any problem updating it. but when the last bin changed and I tried to update my flu, It will not update. I tried everything from turning it on when b flashes to wait for whole b- 75 appear twice and then upload but I am not able to make connection with the receiver.I even went an bought a new cable but still have the same problem. I have tried using loader2 and stb update and fortecstatstb and everything. Do you think I fried something on my reciver. help..thanks..hope I gave the right information.
Username: Asharfi
Post Number: 1518
Here are the instructions that you can use when load any new bin into your Pansat 2500 or Pansat 2500 CLONE units. This is also for the converted Pansat 2500/Pansat 2500 CLONE FTA units.
Instructions:
- Please turn OFF your receiver
- Connect your receiver to your computer using RS 232 female-female Straight Cable
- Now open the Blacklist STB Updater 1.4.0.0
- Now, please select the "BIN" option on the Blacklist STB Updater 1.4.0.0
- Now please select the correct "COM" port on the Blacklist STB Updater 1.4.0.
- Now, please click the "Select Bin" button on the Blacklist STB Updater 1.4.0.0
- Now, please look for the latest bin and click on it
- Now, please turn ON your receiver and as soon as you see the first "dash light" on your receiver's front panel, click the "Write Bin" button on the Blacklist STB Updater 1.4.0.0
- Now, please wait and let the bin download process complete
- When it's done, your receiver will REBOOT automatically and soon you'll see B 7 5 flashes back and forth on your receiver's front panel
- That flashing B 7 5 will stop and freeze on number 5 for 30 seconds
- After 30 seconds or so, your receiver will automatically boot (It'll turn ON automatically, after 30 seconds)
- Now, please turn your receiver OFF and disconnect it from your computer
Note: After you finish with the above steps, you have to re-scan your satellite(s). After you're done with that, you have to enter the latest keys (Dishnetwork or BellExpressVu). Here's what you need to do after you re-scan your satellite(s):
- Go to MENU
- Then, go to Parental Control / CAS Control Menu
- Then, go to Second/CAS Pin and enter 0000
- Then, go to Set Default Key
- Then, go to Nagravision 2 to enter the latest Dishnetwork or BellExpressVu keys
After you enter and store the latest keys, please EXIT the menu and start watching TV!
Instructions provided by AV!
Username: Lamis
Post Number: 12
hi AV HOW ABOUT VIEWSAT EXTREM IS THERE ANY NEW BIN FOR IT THANKS FRIEND
Username: Koko_wawa
Post Number: 96
All SV models files at www.totalfta.com the official site for VS and SV Enjoy. For VS files just wait they should be ready soon
Username: Way2smart
Post Number: 288
All Sonicview and ariza files at
http://www.dssworld.co.nr/
