Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 50 Registered: Nov-07 | I live ins South Florida and cant even find a place that know what the big three is and every one sounds lost???? Does any one know any were that know a shop around the Miami Area ???? Or even up State ??? |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 903 Registered: Nov-06 | It's not hard, do it yourself... I could do it but it wouldn't be worth your travel...... sorry...... |
Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 53 Registered: Nov-07 | Any one have a diagram of doing this ???? |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 909 Registered: Nov-06 | No but its simply replacing 3 wires to a thicker cable. here is a link to some BIG 3 kits.. http://www.edesignaudio.com/edv2/index.php?cPath=28_56 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5048 Registered: Dec-05 | talk to drivingreckless, he lives in tampa, maybe he can hook you up with some workers IDK |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2266 Registered: Jun-06 | http://www.the12volt.com/installbay/forum_posts.asp?TID=73496&PN=1 |
Bronze Member Username: KhaePost Number: 79 Registered: May-07 | hey nale wut kinda set up u got?? so u from portland too huh??? u know ne competetions around our area??? cus if there is i wanna get all my stuff done.... by summer time |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2308 Registered: Jun-06 | Yeah, I live in Portland. I've talked to Torn a couple of times. As far as I know, there is zero competitions scheduled around here. Some pop up from time to time...you just gotta keep an eye out. I've went so far as to email a couple of organizations to ask and they said none were scheduled. This is what I'm running: H/U: Pioneer Premier DEH-P480MP Subs: 2 Fi Q 15's dual .7 ohm Amp: PA A3000DB Box is 8.0 CuFt after port and Disp. tuned at 30Hz Built By Bassman3 Mids: Dayton RS180-4 7" Reference's Tweets:1 Pair of CDT DRT-25 1" silk tweets. Amp: KX100.2 200A Iraggi alt. KnuKonceptz KLM 1/0 Ga. wiring Big 3 with Lightning Audio 2 Ga. wiring |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5553 Registered: Jan-06 | hey robert i live in jupiter ill be down around christmas time i can do it for you but i doubt you want to drive 1.45hrs i might be down in hollandale but i dont know for sure. anyway if you need an HO alt call up riviera generators they might be able to help you out. if you cant find anyone to do the big 3 they probably will do it if you tell them what it is. but really its easy so you should be able to do it yourself. just google it and their are some good guides or just keep asking here. just buy some wire 10ft should be good knukonceptz.com is cheap. go to an auto part store to get ring terminals dont order them online. |
Bronze Member Username: KhaePost Number: 81 Registered: May-07 | oh did u go to this years contest? at PIR?? it was some something.. where u get ur h/o alt at?? i needa get one too for my kicker amps |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2314 Registered: Jun-06 | Nah, I didnt go to street warriorz. I had pre-paid reservations at a campsite at pine hollow. And I didnt find out about it until the weekend before. Did they meter on a TL? I got my alt from Iraggi but I wouldnt suggest him. I've had nothing but problems. |
Bronze Member Username: KhaePost Number: 83 Registered: May-07 | o0oh i dont rember a tl but i rember a geo and a si haha where u think i shud get my alt?? u got aim?? |
Bronze Member Username: KhaePost Number: 84 Registered: May-07 | nah i dont rember a tl but a si an geo lol u got aim?? |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 2317 Registered: Jun-06 | I do have aim, its the same as my screen name here. But I would be much easier to get ahold of by email cause I dont get on aim very much. I'm gonna send you a pm with my email address. |
