2 Power wires one amp?
Username: Vivi2000
Post Number: 16
I have extra 10 gauge power wire from my last install. The amp i am looking at requires 8 gauge i believe. My question is if I can run 2 power wires(10 gauge) from my battery to this amp and it will be ok, or do i need to get bigger wire and run only one wire to it. The amp im looking at is
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16411
Im not asking for specifically this amp either, im just wondering in general.
Username: 420alldaylong
Post Number: 2972
If it was me I would use one 8gauge but if the amp can take 4 gauge I would use that.
Username: •cam•
Post Number: 1113
You need to fuse both of them separately, but it'll work.
Username: Nd4spd18
Northwest PA
Post Number: 4195
If the amp takes 8 gauge, two 10 gauge wires would work. Like cam said you need to fuse both with the correct size fuse for 10 gauge.
Username: Vivi2000
Post Number: 17
ok so if i do happen to get that amp, since it has 2x20a fuses on it I would have each line have a 20a fuse or a 40a fuse?
Username: Nd4spd18
Northwest PA
Post Number: 4198
Fuse size is based on the wire gauge not the amp. Use the table:
http://www.bcae1.com/wire.htm
Username: N2audio
Lawrence, Ks USA
Post Number: 1419
But smaller won't hurt anything. 2 x 20 will work fine.
Username: Sinful_systems70
15 INCH WANG...
Post Number: 904
"Don't go the cheap route" just get the biggest wire possible so there is less voltage loss/ resistence in the power cable itself.... JMO
15 INCH WANG...
Post Number: 905
^^^ Doing this would get more voltage to your amp..... Bigger cable = less resistence and more power transfered
Username: Johnfiac
A-ToWn, Bangn aint easy ....when u g...
Post Number: 3921
"You need to fuse both of them separately, but it'll work."
No you dont... run the same fuse to both under the hood just make sure its the right size
Username: •cam•
Post Number: 1136
If he's running two cables, he needs to fuse each one for half the amps max current draw. Since it is in parallel, the current will split, therefore 20 A through each, when the amp is cranked. This, I know for a fact.
MS says to choose your fuse size based on the wire gauge, but a short will allow a ridiculous amount of current to flow, so as long as you stay under the amount that the wire is rated to carry for that length, it's all good, I believe. Feel free to correct me.
