2 type r's and a mtx92001d amp. hows that?
Username: Mike_16
Reedsburg, Wisconsin Us
Post Number: 714
so i wana get 2 r's just for budget subs righ tnow and get teh amp i was origanly gon aget fo rteh 2 bl's but cant afford teh bl's so i am gettin 2 r's i wana kno wif i get teh r's in dual 4 ohm wired to 1 ohm.. but with that amp running at 1 ohm it is capable of doign 3800 some odd watts rms the birthsheet said. but i wana know if i kept teh gain all teh wya down if il be able to use that amp on those subs? or what about 2 ohms dual 2 can be wired into 4 ohms and 2 ohms right?
Username: Mike_16
Post Number: 715
ohh that amp does 2000 rms at 2 ohms so woudl that be good for 2 dual 2 ohm type r's or not? i hear dthere capable of doing 1200 a piece but its not healthy for em. but would about 800 a piece sound nice? sinc eit does 2000 rms would that be good for em ?
Username: Talon01
12 audioque 2.5 145.2 ..., Pa Usa
Post Number: 387
it will work keep the gain down and youll be fine
Username: Shade
Moxee, Wa U.S.
Post Number: 488
your R's should take 800rms, just watch ur gains and make sure ur sending a clean signal. congrats on the buy
Username: Somedonniedude
Illinois United States
Post Number: 448
If that amp will do 2000wrms @ 2 ohms, then get the dual 2 ohm R's. Then if you ever want to add another type R or two, you will have enough power to do so correctly. (dual 4's will still work just fine tho).
Username: Mike_16
Post Number: 716
thanx.. and donnie how wil 4 ohms work? if i power those at bridged 1 ohm theyl blow lol, but unless i didnt bridge them btu then there isnt enough power to them so il do dual 2ohm. thanx guys. il try to get pics when i get the stuff.
Post Number: 464
What I meant was: If you get 2 dual 2 ohms subs, you can wire them up to 2 ohms on that amp, so you would get 2000 watts from it, 1000 to each sub (which you dont need that much, but its up to you)
Then if you were to get 2 more dual 2 ohm subs (4 total), you could wire them up to a 1 ohm load on the amp, getting 3000 watts from the amp, 750 watts to each sub.
Also you cannot bridge that amp, its a mono amp.
Username: Nd4spd18
Northwest PA
Post Number: 4176
Don't get an MTX........ get a good 2000 watt amp for around the same price
Username: Mike_16
Post Number: 717
ok i understand now. but i kno wi don tneed 1000 to eatch but how do i make sur ei don tget that much? i waan keep it botu 750 to 800 so how do i do that without changing amps? i wouldnt fit 4 subs in my trunk unles it was sealed lol..
Username: Nd4spd18
Northwest PA
Post Number: 4178
Use the calculator
http://www.subwoofertools.com/forum/setgain.asp
and enter the amount of watts you want to get from the amp, not necessarily the most it can do.
Username: Mike_16
Post Number: 718
yes tel em a amp better for cheaper and i will get it ... just tel em witch one..
Username: Mike_16
Post Number: 720
ok that thing sais my target is 63.2 volts. wtf lol. that simpossible. wust that mean. 2000 watts into 2 ohms liek whye dit bring that amoun tof volts up? an di wante dteh mtx cuz i am only usuing the r's til i can afford bl's or dd . and thta amp wil be good with 2 bl' that shwy i am getign it an dppl say its wel underated and good at 1 ohm..
Username: Talon01
Post Number: 399
my birthsheet says 2600w at 2
3800 at 1
my voltage at 2 ohms is set at 72v
Username: Talon01
Post Number: 400
"Don't get an MTX........ get a good 2000 watt amp for around the same price"
show me an amp with the features of my amp for the 400 i paid.that can produce almost 4000w
Username: Insearchofbass
Post Number: 7209
^^^ x2 on that...for the price I doubt that amp can be beat
Post Number: 7210
The only thing ill say is whatever frequency you set the gain to say 50 hz for example it will produce more power below that frequency. So be carefull.
Username: Mike_16
Post Number: 722
ok scotts !!! wut amp do u have and wear can i buy it at let me know asap thanx.. and i only need about 1600 wats for teh r's til i get my bl's an di dont wana blow my r's when i get em. so if ure amp would work then let me know thanx.and sean id keep the gain all the way down cuz its sutch a strng amp for r's lol
Username: Talon01
Post Number: 406
i got mine from ebay and its the one you have in the title ta92001 set your voltage at 56
Username: Talon01
Post Number: 407
i was defending our amp from ms mike
Username: Nd4spd18
Northwest PA
Post Number: 4189
If you already have the amp then lets not worry about getting a different one
63.2 volts AC is correct for 2000 watts at 2 ohms so whats the problem?
Username: Mike_16
Post Number: 723
ok i got confused im ok now though. so how do i even set the volts?
Username: Nd4spd18
Northwest PA
Post Number: 4203
Go to that link I gave you. Click interactive tutorial. Do what it shows you.
Username: Mike_16
Post Number: 724
ok thanx allot everyoen now i know hwo to do that witch helps allot cuz ive always wondered how do i know hwo to make sure when i turn my volume up allot it stil sounds good, wle that helped me now i just gota get the volt meter and amp.subs wiring to. but ill have the subs on teh 27th of december and wirring. but gota wait til i get another check fo rmy amp. but thanx. so wut do u guys think 2 of the r's would sond best at for listening to rap? wut hertz? 33-35?
Username: Extrmndor3
Http://crazydbs.freefo..., ^^^NEW FORUM
Post Number: 7152
id get some phoenix gold rsd instead of the rs
Post Number: 7222
the phoenix gold octanes are more efficient than the rsd's but I dont see them on ebay
Post Number: 7223
they are also more efficient than the alpine type r's but efficiency isnt everything though
Username: Mike_16
Post Number: 725
ok efficiant as in they wil work better? wel idk i heard lots of good things bout teh r's and there only $110 a piece so yea. idk . cant they handle about 800 rms people say?
Post Number: 7226
well from what my bro said about the type r 12's stick with them
Post Number: 7153
i got a type r 15 and one one of my pgs are as loud btu with much better sq... i seent he tcab versions of the type rs and my pgs are the same and alil louder..
i still get some pgs
Post Number: 7236
are the rsd subs the ones your using with your 6 12's set up
Username: Mike_16
Post Number: 726
ok thanx. but im sil stickin with teh r's .
Post Number: 7155
na the octanes zrs
Username: Mike_16
Post Number: 728
i hope with that amp and a good box itl sound nice.
Username: Mike_16
Post Number: 729
ok i have a ? if i get a box tuned to 35 at like 3.5 cu ft wil that be good for rap music? and when doign that step for re tuning for volts it sais put in a tuning cd wel how do i knw what the song wil be tuned at? i have no idea
Username: Mike_16
Post Number: 730
and another thign i only wan agive teh r's bout 750 rms so how wil i do that when teh am p wil produce 2000 rms or more and btw i won thave a charging system yet lol.. so wil that knock off a few hundred watts? so i wont have to worry bout blowing the subs?
Username: Mike_16
Post Number: 731
BUMP
Username: Talon01
Post Number: 441
mike i showed you to set the amp at 56v to get 1600w so you wont blow the subs at a 2 ohm load
Username: Mike_16
Post Number: 732
ok thanx i didnt see that. ok sweet. wel once i get the volt meter and stuff i might need ur ehelp on wut seetign to put the meter on to set it right..
Username: Talon01
Post Number: 447
no problem let me know when your ready
Username: Mike_16
Post Number: 733
alright.. and how much do those things cost? u can buy em at walmart and other places right?
Username: Talon01
Post Number: 451
i dont know if walmart sells them i know lowes and home depot does
Username: Talon01
Post Number: 452
20-300.00 depends just make sure its digital
Username: Mike_16
Post Number: 734
ok il get oen at teh depot.
