Bronze Member Username: Slovenian6474Post Number: 20 Registered: Aug-06 | I've got a 600rms @ 2ohm Alpine amp that's sitting lonely in my car. My single 10" type R got damaged in an unfortunate event and I need something to replace it. It was a good sub but i'm looking for something with more kick. Probably 2 of these would work but since i'm in the position of choosing different subs, I thought i'd get your guys' opinion first. Would it be possible to power 2 subs off this amp and still get high quality yet feel more bass? I was thinking maybe 8" or 10" L5/L7s. Also I read in another thread about Diamond Audio subs. Maybe one or two of those? I'm completely open to suggestions and comments. Thanks. |
Gold Member Username: HdubbTeam Revolution Post Number: 2966 Registered: Nov-04 | imo audioque sd2.5 or a stereo intergrity bm. =) just make sure to get the dvc 4ohm. =) |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 401 Registered: Jun-07 | audioque 2.5 12" |
Bronze Member Username: Slovenian6474Post Number: 21 Registered: Aug-06 | I've got 2 votes for the audioque 2.5. You guys talking one of these right? Any idea how this would compare to my type r? |
Silver Member Username: JnoelAIM= j69noel, KY Post Number: 494 Registered: May-07 | hey i got a 15 inch treo ssi for 220 shipped...if interested email me at ptownboy420@hotmail.com |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 404 Registered: Jun-07 | my buddy has a type r its a little crisper in the lower end but overall the que crushes it and yes just one 12 |
Bronze Member Username: Slovenian6474Post Number: 22 Registered: Aug-06 | Thanks for the offer J, but i don't think a 15 will fit in my car. And one thing i forgot to mention is that i usually listen to rock-ish type music and not to much rap. That is the reason I went with the 10" originally. Scott, you think the 'que will work better for rock music in a 10" or a 12"? |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 405 Registered: Jun-07 | the 12" and disturbed slams on that sub at least on mine |
Bronze Member Username: Slovenian6474Post Number: 23 Registered: Aug-06 | Well, sounds good. What kinda box do you use? Sealed? What size? I'm thinking I'll order the sub and pick up a box locally. |
Silver Member Username: Mj23dynastyHarrisburg star city, Pistolvania USA Post Number: 276 Registered: Oct-07 | i got a 12" JBL GT4 for 100 shipped great sound quality!!! you interested? |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 408 Registered: Jun-07 | 2.5cf tuned at 38 hz slot port |
Bronze Member Username: Slovenian6474Post Number: 24 Registered: Aug-06 | Wow, pretty specific. Is that you have? |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 409 Registered: Jun-07 | yes thats my daily box |
Gold Member Username: InsearchofbassPost Number: 7218 Registered: Jun-04 | actually Scott your daily box for the audioque sd 2.5 12 is 2.5 cubes net tuned to 35 hz |
Bronze Member Username: Slovenian6474Post Number: 25 Registered: Aug-06 | Did you have someone put this together for you? I stopped by a local indepedent car audio place yesterday and they weren't even sure the volume of their boxes. I'm thinking it might be better to get it built by someone if it isn't to expensive. Also while I was there, I checked out their subs. The guy there's recommendation was a Diamond Audio 12" D3. Right now I'm leaning heavily towards your Audioque, but what's your take on the D3? |
Gold Member Username: HdubbTeam Revolution Post Number: 2996 Registered: Nov-04 | thats his brother. sean is scotts brother. |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 415 Registered: Jun-07 | i build my own stuff, and yes sean is my bro tyvm hunterw, cant say about the d3 i have only heard the d6 they have ecellant sq the aq is a sql speaker |
Bronze Member Username: Tblazer74South Salem, NY USA Post Number: 71 Registered: Jun-07 | Dwight I may take you up on that JBL. How many watts can it handle/whats its VC config? How old is it too? Got pics? |
Silver Member Username: Mj23dynastyHarrisburg star city, Pistolvania USA Post Number: 307 Registered: Oct-07 | Its just a lil sub with great sound qaulity wrms is 250. Its a good quality sub and I'm letting it go for dirt cheap |
Bronze Member Username: Slovenian6474Post Number: 26 Registered: Aug-06 | Sweet, well the aq sounds like what i'll be going with. I was thinking of trying out building my own box. Where is a good place to look for mdf board? |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 422 Registered: Jun-07 | lowes |
