Gold Member Username: Tremor1127Fi Post Number: 2507 Registered: Aug-06 | can you get an 8 ohm final load with four 2 ohm subs? or even two of them? |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 914 Registered: Nov-06 | DVC or SVC Dual 2 or single 2 ohm |
Silver Member Username: Vc23Sandusky, Michigan U.s.a Post Number: 204 Registered: Mar-06 | with 4 subs you can wire em to either 1 ohm or 4 ohms...and with 2 subs you can wire em either 2 or 8 ohms... |
Silver Member Username: Vc23Sandusky, Michigan U.s.a Post Number: 205 Registered: Mar-06 | thats with dvc 2ohm... |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 917 Registered: Nov-06 | Well???????? Are they DVC or not????? |
Gold Member Username: Tremor1127Fi Post Number: 2508 Registered: Aug-06 | dar. sorry. just single 2 ohm VC subs. |
Gold Member Username: Tremor1127Fi Post Number: 2509 Registered: Aug-06 | and hey VC, im shipping the amp tomorrow... |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 921 Registered: Nov-06 | two would be 4 ohms and 4 would be 2 ohms... |
Gold Member Username: RideredderCornell, IL USA Post Number: 1147 Registered: Sep-05 | http://mobile.jlaudio.com/support_pages.php?page_id=160 That only says 0.5ohms. |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 936 Registered: Nov-06 | http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2SV C%5F2%2Dohm%5Fmono http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=4SV C%5F2%2Dohm%5Fmono |
Silver Member Username: KravenbloodOhio Hmmm Post Number: 334 Registered: Aug-05 | if you put them all in series its 8 ohms 2+2+2+2 = 8 ohms |
Silver Member Username: KravenbloodOhio Hmmm Post Number: 335 Registered: Aug-05 | all parrel would be .5 sereies parrel whould be 2 ohms |
Gold Member Username: Tremor1127Fi Post Number: 2510 Registered: Aug-06 | "if you put them all in series its 8 ohms 2+2+2+2 = 8 ohms" can you show me how to wire this? |
Silver Member Username: KravenbloodOhio Hmmm Post Number: 337 Registered: Aug-05 | i can explain it take yuor first sub run the neg wire to the pos of your second sub then sec subs neg to the pos of the 3rd then neg of 3rd to the pos of fourth you will end up with a open positive on first sub and open neg on fourth sub take a dmm and it should read 8 ohms if you did it right |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 6000 Registered: Jul-06 | Oh my. I can't believe you're asking this question Tremor, you've been here way too long not to know this. Take the positive from your amp and put that into sub number 1, now take the negative from sub number 2 and put that into the positive on sub number 2, take the negative of sub number 2 and put it into the positive of sub number 3, take the negative of sub number 3 and put it into the positive of sub number 4, take the negative from sub 4 and place it into the negative on your amplifier. Done. |
